Does Honda actually test these cars on "real" roads? (screeching noise from front wheel)
glhs
New England
2024 Acura Integra
I'm 2 weeks and 600 miles into ownership of this Integra Type S and my wife calls to tell me she's pulled over to the side of the road as the car started making some massive screeching noises during her commute home.
Some quick checking on the CivicXI forums indicates this is a known issue, common to the CTR and I guess now to the ITS as well and that the noise is literally a pebble or rock that gets stuck between the backside of the rotor and the backing plate.
While we don't live near any dirt or gravel roads we do live in New England and its not uncommon to find sections of patched and crumbling pavement or the loose rock here and there. Is anyone else in the snow belt having these issues with their ITS? Is there something about the design of the big brake package on the CTR/ITS that makes it more prone to this issue than any other car we've owned, Honda or otherwise? I reached behind the rotor to wiggle the backing plate and see if any gravel might would fall out and it seemed to me like the backing plate has a smaller diameter relative to the rotor than other cars I've had.
Anyone else had the issue yet? Has anyone done anything drastic like fabricate a bigger backing plate, add more clearance from the backing plate to the rotor, or even removing the backing plate? If this happens once or twice a year it won't be a big deal but every few hundred miles would be unbearable.
I think the factory sticky PS4S tires are know to throw some rocks. I know there were a few reported cases. I haven't experienced it yet but switched to all seasons.
Bend it and send it, bud.
This has happened with most of my cars. kind of a pain but is what it is. PS4S tires are likely the culprit as they are super sticky when warm. For those that have tracked them, you know they get covered in rocks and pebbles the second you pull off the track.
East Coast
i got the splash guards installed specifically to help mitigate this, so hopefully they make a difference.
i had been driving a '15 Si up until i traded it in for my new ITS and i had been running these same tires for a few years and i had this happen once or twice, so i made it a point to get the splash guards this time.
3100 miles and this hasn't happened. In all the cars I've ever owned in my life, I've had a pebble stuck behind the dust shield exactly one time.
It sucks when it happens, but I wouldn't expect it to be a common occurrence, and definitely nothing exclusive to this car.
It's 99% a sticky tire issue, 1% bad luck, not really car dependent. Driving a 9th gen Civic Si for the past 10 years with Michelin PSS tires, I've had at least a few instances where this has happened. First time is the scariest, you think the wheel is going to fly off. Also, you up your chances drastically the more the wheel is turned as you drive over the pea sized gravel.
I found that the best way to rectify it is actually to pull into a parking lot and go in reverse. Doesn't always work but it has a much higher rate of success short of using something to fish out the rock manually.
Yep! Put it in reverse, give the throttle a jab, and then stop suddenly. Always works for me.
East Coast
i was really tired when i wrote this last night and despite that i still couldn't really sleep, and i was laying awake in bed around 5am and i thought about this and i realized that the splash guards will do nothing to prevent a rock from being thrown up into your brakes, and also that i am a tard
zooka
Belleville, IL
This happened on a few cars I owned before, but not yet on the ITS. Has nothing to do with Honda or any manufacture creating a flaw\testing. Just the the luck of the draw of a tiny rock projecting just right in between the shield and the rotor.
East Coast
can somebody take a picture showing where exactly these rocks get stuck at? i've had it happen before as i mentioned but i was able to dislodge it by driving, but next time it happens i would liek to pull over and know exactly where the rock is so i don't fumble around in the dark or whatever
zooka
Belleville, IL
There are metal shields on the rotor and tiny rocks can pop in here
Acura Integra Does Honda actually test these cars on "real" roads? (screeching noise from front wheel) IMG_0096
Steve48
Vanc. Island
'25 Golf R
Happens all the time to BMW's as well...I remember the first time it happened to me several years ago, it sounded like the car was about to die. But as others have mentioned, it is just small rocks getting stuck and either slight bending of the shields or going into reverse and forward cured it everytime.
bruejam
Jim
Cincinnati, OH
2026 Performance Red Pearl Type S, 2024 Tiger Eye Type S - RIP
I don't think it has anything to do with sticky tires. This happened to my wife's '22 MDX shortly after we got it. It has only happened twice in a little over a year.
