DAE get little rocks stuck between rotor and brake shield?
STi from DSM
Minnesota
www.youtube.com
I had this happen on mine too. It lasted 1/2 my drive home after I noticed it. (About 4 miles) Finally it popped out going about 50 on a back road.
jd2157
2024 Acura Integra Type S LCM
This has happened to me 4 times in the past month. Last time I considered lighting the car on fire but not sure if that would’ve helped.
Last time I couldn't get the rock out no matter what I did. Jacked it up, checked both rear heat shields, and noticed my rear right was closer to the rotor by a half inch or so. I bent it back, a rock flew out, and haven't had an issue in 4+ months. I used to get rocks lodged every couple weeks because they did shitty chipseal all around me 🤬
dl8468
Rich
Oakland, CA
2025 Acura Integra Type S
Anyone have experience with paragon rotors? Will I have the same issue?
It's the heat shield catching the rocks so a different rotor probably won't help at all. Remove the heat shield or just deal with it as it comes up.
matreyles81
Matthew
Austin
DE5 Type S
I fucking hate when this happens. I am currently staying on a military base, and there are a ton of little pebbles and rocks in my parking lot, which most of the time get lodged in my brake shield. Most of the time I am able to dislodge quickly, but this current one does not want to pop out.
East Coast
ive only had this happen to my ITS one time now. i wasn't able to dislodge it by driving forward and back, but i was able to make it fall out by just lightly wiggling it for a few seconds. that gap they get lodged in is actually pretty forgiving on these cars. when i would get these in my old Si they were a pain in the ass to get out, like the gap was smaller so they would really get jammed down in there.
Bend the shields back.
stan23
Stan
SF Bay Area
DE5, GT4, S2K, Tacoma Hybrid
Happened to me when I dropped off my kid at basketball practice. I went up a slightly gravelly driveway and got a pebble stuck in the front driver-side rotor. The sound was insanely loud and I couldn't lodge it loose, so I drove home making a complete racket. Took long screwdriver and poked the shield and the tiniest pebble fell out.
