Scrodee
- Thread starter
- #1
My neighborhood and a lot of the streets I drive have lots of small rocks and bits of asphalt on them. At slow speeds, the tires are slinging these all over the wheel wells, I'm sure others have experienced this. That's fine and to be expected with sticky tires. Problem is that every now and again (far too frequently) little rocks will get jammed between the brake shield and the rotor. What results is an awful squealing and loud metallic pops and bangs until it finally gets dislodged. This has only happened on the front.
Most of the time they come out after a few hundred yards or a turn but I've had some stay in for miles. I had one instance where the rock would not come out even after hitting 45+ MPH. I was several miles away from home so I stopped and tried to scoop it out by scraping a piece of cardboard and then a straw between the rotor and the shield but it would not come out. I had to get home and remove the wheel. I had to use a borescope to find the rock and then it took me another 10 minutes to get it out; had to use long needle nose pliers. The rock seemed to have asphalt on it, I guess it may have sort of glued itself to the shield.
Upon inspection, the brake shield is quite close to the rotor and has a weird shape to it. It has a strange shape to it compared to normal brake shields runs completely parallel to the rotor rather curving away. I assume this design has something to do with the two-piece setup and/or for cooling?
I check the rotors every day and they don't look to be developing any nasty grooves but I'm worried that this will eventually ruin my rotors.
Maybe it's nothing but an annoyance but it's awfully embarrassing to ride through my neighborhood with a terribly loud screech...
