- First Name
- Gordan
- Joined
- Jul 9, 2024
- Threads
- 12
- Messages
- 1,888
- Reaction score
- 1,324
- Location
- Kansas City
- Car(s)
- Integra type s
Correct!!Okay, I have to claim some ignorance here, as all my previous track experience was in various RWD cars. But it sounds like you are referring to the technique that I knew as trail braking. You stay on the brakes past turn-in, and at some point between there and the apex, you lift off the brakes and squeeze on throttle. This helps with the rotation in cars prone to understeer. I used it to good effect in an E92 M3 with DCT. When dealing with 3 pedals, it is more challenging.
Getting it right is fine tuning the brake release to get a smooth rounded peak. Trail braking is part of it, but also it's how smoothly you release the brake (also why brake pads like gloc and carbotech are famous for their "brake release characteristics"). Sweepers are the best place to demonstrate and practice the technique because that's where you spend the most amount of time slowly releasing the brake and the longest time without any pedal input. A neutral chassis like the type s responds well to medium brake or lift off because of the fore-aft balance. Understeer prone cars like corvettes and 911s require more brake input, but can also take throttle input way earlier. Oversteer prone cars like the 86 need much smoother brake release to maintain balance. Generally speaking, the fastest cars are the rwd ones that tend to understeer a bit because you can get on power sooner.
The "shark fin" on a speed chart is what you're looking for to identify how smooth that brake release characteristic was. The screenshot below is from a lap I did at hallet earlier this year. It's a little lumpy because GPS was acting up from heavy cloud cover, but the areas I highlighted in yellow are good examples of what I'm typically looking for. Speed charts are awesome! You come off track and in literally one glance you know how well you did and how "smooth" you were.
Edit, dropped the wrong screencap. Here's the right one
