Rear Defogger performance
solman
Sol
Central New Jersey
I have the type A with tech and I believe the rear defogger is slow to clear the window. While the mirrors clear fast the back glass seems to take a solid 15 minuets to clear. Are others finding about the same time frame or is mine not up to spec?
My rear window had a lot of condensation tonight. Between 10-15 minutes on my way to my destination and then again on the way back, and absolutely no effect after pressing the button to clear the window.
RRP RSX-S
2013 Mustang GT
You guys have tint? Some lesser quality places cut the connectors so the defrosters don’t work anymore.
I just checked, and all lines are intact. My tint guy is super reputable, and all his pieces are precut by a machine. If I remember correctly, he just heats it up while on the outside to get it to curve correctly prior to final installation.
I still need to check the 30A fuse under the hood.
I didn’t see any actual connection points around the window. I’m guessing I’ll have to remove the window trim pieces to gain access and take a measurement with my multimeter.
The rear defrost seems to not work well with fogged windows. I can confirm both this, and after our first snow last night, that it works just fine for snow/ice. There is likely a thermal switch regulating temperature of the heater itself opposed to just applying a steady current. This wouldn't surprise me at all being a resistance heater and the abundance of microcontroller options there are in the industrial environment. I obviously can't confirm this without probing the wiring which I'm not going to do while my car is under warranty.
Last vehicle I had there was a recall for the rear defrost melting the wiring harness. It worked super quick though!
I have also noticed that the car's windows in general seem to like to fog. I read online that some of the materials used in manufacturing of the interior pieces can cause this and diminish over time.
I found the under hood fuse, but it’s different than the traditional ones. I didn’t mess with it.
Instead I grabbed my multimeter and took a measurement of the rear window. It read 12V in a few different places.
I guess it’s what submitaweasel said…it’s not the best at defogging. I’ll test it out under different conditions.
I just use the rear defrost for the mirrors which seem to heat up quickly. Never use the rear window since I'm always passing people. I only care what's in front of or beside me.
SKL
See
NYC
Mine didn't work great when I first got the car and it fogged up even when I'm alone.
But after a couple of cleanings, it's been working great. No issues here.
