Warranty Extension 1.5t Head Gasket Issue
gregbutler_20
Greg
Maryland
I see what this says, but doesn’t this only apply to the 1.5t motors?
gregbutler_20
Greg
Maryland
So far, yes. People on reddit have mentioned that the 2.0 has this issues as well, but the number of cases is smaller. It took honda years to admit it about the v6 and the 1.5t. I wouldn't hold my breath on them mentioning the 2.0 until the numbers pile up.
rhythim
TN
23 A-spec 6MT
This will be the first warranty that I intentionally void on the car. Damn the torpedoes. I noted the VC gasket on mine was leaking over the weekend, so I'm going ahead and putting head studs in it next oil change. If the HG goes anytime after that once it's tuned to match the supporting bolt-ons the car already has, so be it, that's on me. Pulling the head and/or entire engine/trans assembly in these cars is stupid easy anyway. I'm actively searching for a used engine to build into something spicy as it is.
Punisher666
Ben
Kentucky
2026 Acura Integra A-Spec 6MT
I usually go to a DIY garage (they got lifts and they recycle the oil for me) that gives me receipt and I get to put what I was there for. Also save the box tops of all my oil filters.
Very happy to see this bulletin as I learned about the HG issue the weekend after I bought the car. lol
GenXRavensFan
Scott
San Antonio, TX USA
Integra
So I just bought a '26 Aspec Tech less than a month ago. After the free oil change from Acura, I was planning on running 5W30 oil instead of the recommended 0W20 as I live in South Texas, and I do lots of stop and go driving. But I do the changes myself, so the receipts will obviously show that. Anybody know if that will void the warranty?
no, it won't void the warranty. they would have to prove the increased viscosity caused the head gasket to fail, which isn't possible.
Should I remove the base tune I have, or is that irrelevant?
no point. they can see if you've been tuned previously, even if you flash it back to stock.
sventhecivic
Gaetano
2017 Honda Civic EXT
Gotcha, thanks! So I guess I'll see if my dealership makes a fuss over it or not. Is this TSB something I should try to get addressed now even if my Integra seems to operate just fine?
I'm reading more about the TSB now, but I'm having a hard time finding some concrete links with recommendations.
GenXRavensFan
Scott
San Antonio, TX USA
Integra
Thanks, I appreciate the info. As far as tunes go. I'm waiting for KTuner to unlock mine and send it back. Once they do, I wasn't planning on putting a tune in just yet, but I did want to get rid of the auto start BS. I don't always remember to shut it off every time I get in and it drives me nuts. Do you know if using the KTuner for that void the warranty?
technically, yes, that would void the warranty. but, in the end, it's up to the dealership.
GenXRavensFan
Scott
San Antonio, TX USA
Integra
Thanks, I appreciate the info. I knew I was gonna void the warranty at some point. Obviously didn't know about the HG problem until today. Already bought the car, and probably would have anyway, but now I may rethink when I do things.
I can almost guarantee you won't get a warranty claim through if you tune the car.
But go ahead and try your luck I guess? If a shop's starving for work, they'll probably be thirsty for someone to come in with a head gasket but Honda might crank down on that. Physics implies more boost will exacerbate head gasket ineffectiveness but don't let logic and science get in the way.
I also have not heard a single instance of head gasket issues on the K20. But if you go looking for something on the internet, I'm sure you'll find it.
