Manual shifter question
Miiiisa
US
Hello all, got a quick question about the shifter. When I shift to 2nd gear in my integra, I can feel that it is bumpy, or clicky? I don't know how to describe it but it is not smooth, feels like I rubbed into something. Is this normal or you shouldn't feel anything when shifting. It only happens when shifting to 2nd gear. Thanks!
Quick edit: had this problem since I got the car, right now it has 3000 miles on it, I thought it is normal and would be gone after I drive the car for a while, but it didn't.
KiloFTW
American Midwest
23 Integra M/T
Hard to say without experiencing it. Does it feel the same if you shift at lower vs higher RPM? From personal experience, shifts sometimes feel very smooth, and sometimes feel "notchy" as some youtube reviews described. I can't recall whether the difference in feel aligns with a specific gear.
Miiiisa
US
Thanks, I guess It's ok for now, I'll ask them about it when I do my first oil change. When do you usually shift from 1st to 2nd?
KiloFTW
American Midwest
23 Integra M/T
I'm still learning this thing, but usually after 3k. I've been more focused on rev hang and not shaking the car, less on shifter-feel. If I have someone else with me, I've found it better to shift earlier, closer to 2k.
Mine doesn't like shifting into 1st or 2nd with a cold transmission. Second is notchy and first is a battle of wills. Once it warms up it smooths out and shifts fine but it needs the revs matched when cold.
JohnV
John
St. Louis MO
I'm with Kilo on it having a notchy feel. But for me it is fairly consistent for all shifts, all gears.
For shift point, if I'm accerating with traffic, usually between 3000-3500 into second. But if I'm just rolling, I may go as low as 2000 rpm, as I have difficulty keeping the ride smooth in first. I tend to have throttle sensitivity and the car bucks back and forth a bit.
SiTurbo269
Joey
2023 Integra S-Type
Shift poo poo sometimes, I too wonder wtf. This shifter sometimes not smooth. Sometimes don’t want to go in gear.
SKL
See
NYC
Typical Honda 2nd gears - had this in my 5G Prelude but the Integra is much less grindy. I swapped in Redline MTL with great success and had that for over 220k miles without issues. Your mileage may vary since others didn't have the same results in the Prelude as I did.
I plan to run Redline again at 30k miles. Maybe at 10k if this persists and annoys me more.
Nycvic
Vic
NYC
2023 Acura Integra A-Spec 6MT
I third this as well. Notchy from 1st to 2nd @ low speeds and RPMS in The 2k-2.5k range
Everybody saying second is notchy:
Does the feeling go away after 15-20 minutes of driving?
BKK Jack
Jack
NoVA
2023 LCM/Red ASpec Tech 6MT
In my experience, it goes away with a heavier shift knob. I put on a 500gm Billetworkz, which was stupid expensive, but my shifts are easy and close to butter smooth.
DaNuKidd
David
Agreed when I installed my weighted knob as well most of that notchyness is gone.
solman
Sol
Central New Jersey
For all the reviews saying this is the slickest manual trans out there I find the shifting is often pretty crunchy. Especially noticeable when the trans is cold. At times it shifts like butter once its been driven a while, other times not so much.
Has me scratching my head and wondering.
Where does one get a weighted shifter Knob and how to drop the boot and instal it?
treyk
Definitely know what you are talking about as I feel it every time I drive and if I'm in the parking garage with the windows down I can hear the trans clunk too. My friend drove my car and said he also feels it and this is well after the trans warmed up. Only happens 1st to 2nd and people on the 11th gen civic forums say its typical Honda stuff so idk what to do other than get a heavier knob.
nawfoo
Kay
South West
Integra
I think you guys are shifting it wrong. Most people shift gears in one motion. Some people jam it into gear. When I shift, I pull it out of gear, stop slightly at neutral and then slowly pop it into the next gear. I've also noticed that the less force you use the more smooth the gears to in. You can practice using just the tips of your thumb, index, and middle finger to push the knob into gear rather than grip it with your entire palm and shove it into gear.
