Where to start with Performance Upgrades?
tegs
24 ITS
Hey guys, I been lurking on the forum for past 3 months, really enjoy all the post..
I picked up my ITS in July, and the only thing I done was put the PRL HVI on..
Like the extra turbo noises lol
Anyhow , I’m trying to figure out what I should do next..
Im bit of a noob at this stuff, but can manage to do my own work..
Main question is what would be the best thing to do with this car to get best bang for performance on the street..Won’t be no track days, we don’t have that option up here..
Should I just get a tune?
Recommendations?
im seeing a lot of talk about a down pipe, anyone care to explain the benefit of a down pipe?
Anyhow, appreciate anyone’s help!!
thanks
joemama
Ben
Houston, TX
I'm in a pretty similar situation. Decided exhaust was the next step and lowering springs. Car is pretty great straight out the box. Hoping AWE finishes building my exhaust and H&R springs come in soon!
As far as down pipe is concerned, based on what I've read it does alter the sound in a positive way, but you won't get much performance gain unless you tune it also. Personally, don't feel like tuning my car for now.
Best bang per buck for power is always tune.
Best bang per buck for performance is driver up skill, but that takes practice and track time, which you've said you don't want.
Best for grip/balance is tire, then wheel and tire pressure tuning, followed by geometry changes (alignment)
bisquick
Brandon
An off-the-shelf tune will be your best bet. If you’re looking for more then start installing supporting mods (e.g., downpipe, front pipe, charge pipes, intercooler, flex fuel kit, etc.) and get a custom tune.
Start with down pipe and a tune.
Then the rest of the items in my signature ?
tegs
24 ITS
Thanks guys..
What’s the big benefit to the downpipe?
Any upside with a downpipe, and no tune?
Thanks guys..
The factory one is restrictive and there would be some gains but most would come with a tune.
Just keep in mind the downside to the downpipe, whether with a high flow cat or not, is that it's an emissions device and if you ever get sniff tested, you'll fail regardless of tune. If you and your state's politicians don't care about emissions, then it's a personal call.
Reducing that exhaust restriction is not as much about peak power as it is increasing rate of spool (because of less restriction behind the turbo directly) and moving the torque band to the left a bit. The result is often a car that drives more "readily" at any pitch of the throttle, closer to emulating a big engine. Instead of feeling like a peaky 4 banger it'll feel a bit closer to a medium v6, with still some turbo lag.
JesterTuned
FL5 Type R, S2000, Ram TRX
I have a few customers that drive bone stock cars with just a tune and they are very happy and not looking to mod. Good gains for less than the price of an exhaust.
tegs
24 ITS
wow, well i dont have to worry about emmision up in Canada..
Will the fumes be really noticeable?
Smell strong inside and out?
tegs
24 ITS
That sounds pretty interesting, do you have a website I could checkout?
If catless, yes the fumes will be pretty strong and if the wind is right when idling it could suck pretty bad.
If high flow cat, the fumes are less noticeable and usually mostly on colder days or on cold start due to the engine running a little richer and just more fuel/exhaust being present in those scenarios. How close the cat is to the source will also determine how much will get through since a warmer cat is a more efficient cat, but also too hot can reduce efficiency. There's a balancing act, and hopefully whoever made the downpipe took the time to weigh the pros and cons of what size cat to use, what type, and what location. A very good design will be within 95% of the operation of a factory setup.
tegs
24 ITS
Is there one you recommend with a Cat?
If your tuned RV6 or Axion whos sells a unit that you can swap a cat put for a straight pipe.
If your not tuned then TSP version.
JesterTuned
Yeah I do! But reach out to me through PM, I don’t want to clutter this thread since it is easier for you to ask me questions that I can answer directly.
