Rear Motor Mount
Do you know if those increase vibration at idle?
Reported to be the very mild. Some say no difference from OEM. Mine still hasn't Arrived
Azkyrie6
Henry
Acura TL, Acura MDX
I’ve only done 3 hard pulls. Didn’t notice any wheel hopping and shifts have thus far been smooth . I wonder how much we’ll get by upgrading RMM
dockleryxk
Richard
East TN
Did yours ever show up?
Looks like I need to return the hasport one I received by mistake. Didn't realize this was holding things up.
nix6speed
Houston
'24 LCM ITS
I replied to this thread. Am interested in the PRL since it's the softest and still rubber. Not finding much else in the FL5 Forums and stay off of FB.
PRL RMM
Edit: just realized that's an Si thread.?ā€ā™‚
PRL RMM
Same RMM
dockleryxk
Richard
East TN
Well damn! Curious to hear what you think when you do get it
ckone2030
Christian
Atlanta, GA
I tried to install the PRL rear motor mount but failed miserably so I want to ask advice from you all that had installed it. I was able to remove the OEM motor mount but I could not insert the PRL mount. The chassis area was extremely tight that I could not push it in. I even used a ribber mallet to force it in but to no avail. What did I do wrong? Any advice would be greatly appreciated.
ZeroGSR
ZeroGSR
2024 Integra Type S (LCM)
You are supposed to use a crow bar to pry the motor up for it to clear. I was by myself, so I used a jack towards the front of the motor until it lined up.
ckone2030
Christian
Atlanta, GA
That is why it did not line up! I will try again tomorrow. Thank you for the advice!
ZeroGSR
ZeroGSR
Good luck, I was lucky and saw another vendor's install instructions (27 Won maybe?) that mentioned that part. Installing my PRL front pipe was worse, that bastard did not want to line up on both ends and without studs in the back it sucked.
ckone2030
Christian
Atlanta, GA
Wow, nothing is easy I guess. My next project will be the PRL HVI when they send the first batch, and then the down and front pipes. Let’s see how much i get done….
Zircular
TN
GONE: ā€˜23 Integra A-Spec 6MT
If the mount is hanging up then it probably isn’t going in straight. Try rocking the engine forward to get the mount’s front bolt into its slot. That should get the mount aligned well enough to go the rest of the way into its bracket on the front subframe.
thosport
AZ
Integra Type-S
The mount isn’t quite symmetrical longwise. Is the PRL engraving pointing up or down?
