Azkyrie6
Do you know if those increase vibration at idle?I ordered a PRL unit from Axion. Just waiting for PRL to ramp up production. I have been waiting 3 months.
Reported to be the very mild. Some say no difference from OEM. Mine still hasn't ArrivedDo you know if those increase vibration at idle?
Iāve only done 3 hard pulls. Didnāt notice any wheel hopping and shifts have thus far been smooth . I wonder how much weāll get by upgrading RMMReported to be the very mild. Some say no difference from OEM. Mine still hasn't Arrived
Did yours ever show up?Reported to be the very mild. Some say no difference from OEM. Mine still hasn't Arrived
Looks like I need to return the hasport one I received by mistake. Didn't realize this was holding things up.Did yours ever show up?
Well damn! Curious to hear what you think when you do get itLooks like I need to return the hasport one I received by mistake. Didn't realize this was holding things up.
You are supposed to use a crow bar to pry the motor up for it to clear. I was by myself, so I used a jack towards the front of the motor until it lined up.I tried to install the PRL rear motor mount but failed miserably so I want to ask advice from you all that had installed it. I was able to remove the OEM motor mount but I could not insert the PRL mount. The chassis area was extremely tight that I could not push it in. I even used a ribber mallet to force it in but to no avail. What did I do wrong? Any advice would be greatly appreciated.
That is why it did not line up! I will try again tomorrow. Thank you for the advice!You are supposed to use a crow bar to pry the motor up for it to clear. I was by myself, so I used a jack towards the front of the motor until it lined up.
Good luck, I was lucky and saw another vendor's install instructions (27 Won maybe?) that mentioned that part. Installing my PRL front pipe was worse, that bastard did not want to line up on both ends and without studs in the back it sucked.That is why it did not line up! I will try again tomorrow. Thank you for the advice!
Wow, nothing is easy I guess. My next project will be the PRL HVI when they send the first batch, and then the down and front pipes. Letās see how much i get doneā¦.Good luck, I was lucky and saw another vendor's install instructions (27 Won maybe?) that mentioned that part. Installing my PRL front pipe was worse, that bastard did not want to line up on both ends and without studs in the back it sucked.
The mount isnāt quite symmetrical longwise. Is the PRL engraving pointing up or down?I tried to install the PRL rear motor mount but failed miserably so I want to ask advice from you all that had installed it. I was able to remove the OEM motor mount but I could not insert the PRL mount. The chassis area was extremely tight that I could not push it in. I even used a ribber mallet to force it in but to no avail. What did I do wrong? Any advice would be greatly appreciated.
