You really feel the limited aero on the rear over 100mph. My buddies type r was spanking me on turn 1 at Pocono even with having 100hp more and better tires.Just saw the video
that dude is freaking fearless! And what he said at the end, totally makes sense. The de5 was only given low speed aero. Folks speculate itās because of the existence of the type r and honestly that makes sense imo
the fl5 has a nice mix of low speed and high speed pieces. Would be interesting to see the de5 get that kind of treatment.
Thatās incredibleYou really feel the limited aero on the rear over 100mph. My buddies type r was spanking me on turn 1 at Pocono even with 100hp more and better tires.
Itās possible the its was nerfed via lack of aero so they could beat the VW GTIās fwd record with a type r instead? Just a guess from me and Iām not basing that off of any info I read or heard but I canāt help but think thatās the caseIt was really awesome to see Misha in our car and have great things to say about it (albeit with HRC upgrades). I called it though while watching, right before he decides to go on his 3rd lap, that he was gonna have fuel cutoff limp mode issues, because that happened to ME at the end of my first track day with the Integra at Big Willow in SoCal. When misha kept bringing up rear aero needed I couldnāt help but keep thinking about this:
the answer was right there HRC! You made that! Wish misha couldāve been in that one at the āring
good insight, I can see that being the case. But reading between the lines of your post, my takeaway is: ITS is too OP, needs to be nerfed so CTR can take the limelightItās possible the its was nerfed via lack of aero so they could beat the VW GTIās fwd record with a type r instead? Just a guess from me and Iām not basing that off of any info I read or heard but I canāt help but think thatās the case
Body roll is what kills the type s and r. The more body roll the more camber is lost on the front outside tiregood insight, I can see that being the case. But reading between the lines of your post, my takeaway is: ITS is too OP, needs to be nerfed so CTR can take the limelightjk
I can't speak to what and why they did something with setup, but I can speak to general aero.Body roll is what kills the type s and r. The more body roll the more camber is lost on the front outside tire
the type r has an advantage because r mode is still enough to make me think a r will experience maybe 0.3 to 0.5 degrees less body roll in a very high g turn vs a type s in sport plus
but the extra power we have from 3k rpm to redline seems to make up for that. More or less
with the same tires both cars usually return about the same times. Or so it seems.
type s makes up time in high speed sections while the type r claws back in less technical turns. However once the turns get tighter and we can start factoring in the camber gains from caster. I think theyād be about equal?
@Victorofhavoc what do U think bro? I feel like youāre super qualified to tell me Iām wrong h or right![]()
this could be a possibility, but from what I experienced with 1/4 tank remaining as shown by instrument fuel gauge indicator, once the car experiences any kind of lateral load and the fuel tank is below a certain level, the car throws a āfuel rail/system pressure too lowā code and goes into limp mode. Hereās the relevant thread on that:I suspect he had limp mode due to overheating from whatever was added in front of the radiator for "cooling" up front.
Oh yeah for sure. That's basically any road car. We're just lucky it's not like a half tank being a problem. Usually you go to a dual pump or baffled/fuel cell setup if you're going to push over 1.2G and be serious about it. For general 20 minute sessions, it's fine... You just fill up 5 gallons after each session and it's all good.this could be a possibility, but from what I experienced with 1/4 tank remaining as shown by instrument fuel gauge indicator, once the car experiences any kind of lateral load and the fuel tank is below a certain level, the car throws a āfuel rail/system pressure too lowā code and goes into limp mode. Hereās the relevant thread on that:
Limp mode track day thread
this was also documented by zygrene in one of his earlier track days with the ITS
so my remedy for this was to always refuel to full when I got below half tank during track days
Great input. Thanks broI can't speak to what and why they did something with setup, but I can speak to general aero.
The type s is more forward heavy than the Fl5. It's going to be more agile and capable at sub 80mph range and faster above 100mph, but like mentioned above, it's not going to be as fast in flying kink corners.
I suspect he had limp mode due to overheating from whatever was added in front of the radiator for "cooling" up front. Also keep in mind that Misha, despite being a good driver, was flogging the crap out of the car instead of backing off to drive to its limits. A lot of that is I'm sure for the clicks, but that also contributes to aero balance and overheating/limp issues. I'm also unclear if it had a baffled oil pan, and a pan is basically necessary the moment you do any track work.
I wish they would have tested the bone stock car with decent tires and pads. I bet it would have gone faster.
