Experience with Jogon center console dashboard panel
A few different companies make these as well. I got all mine off amazon and I have no rattles. They’re stuck on there pretty good and flush.
MNTeggy
Ryan
Minnesota
ā€˜25 Integra Type S
Hi,
If you have Jogon center console dashboard panel, can you please share your experience?
- How's the fitment? Any gaps that you wish were not there?
- Any rattles after driving with it for a while?
https://www.jogoncarbon.com/collect...er-interior-car-trim?variant=1000013696364031
The fitment is good! The only thing is the driver’s side piece sticks out more than it needs to on the right side near the steering wheel. It’s caused zero issues, though. The carbon fiber is thin and light. I used the double-sided tape it comes with and it’s worked very well.
Acura Integra Experience with Jogon center console dashboard panel IMG_0799
My experience exactly. The little piece to the left of the steering column just comes in contact with the steering column. Not really noticeable but I found it odd. Just be careful to get it fully seated in place before you fully peel off the plastic part of the double sided tape. I started with the small piece on the drivers side and the first try I didn't have it sitting all the way flush. It kind of goes into place if you're careful though. Looks great and I would recommend it.
hmm, can't remember. Pretty sure it was ebay or amazon, but it was the Jogon shop.
jugauthi
Justin
Milwaukee
2025 Acura Integra Type S
I have every piece that Jogon makes for the interior installed. I never had any fitment issues with the part you are referencing and didn't have the same issues that the earlier posters mentioned. I did have some issues with a few other parts due to not knowing the proper order of installation, as some parts need to be installed before others otherwise you will have fitment issues/conflicts. Great parts!
roost27
Russ
chicago
2025 ITS
I have all the interior pieces as well as the hood scoop and mirror triangle exterior pieces, all fit great no issues. I ordered directly thru JOGON, Shirley at JOGON is super quick with responses and amazing customer service
dmd2005
Stephen
Abbotsford, BC
I installed my interior Jogon pieces during the winter and the cold temps made some of the pieces come off. I even wiped everything with 50:50 alcohol and water. I had to use some 3M adhesion promoter on the window switch pieces and the rear cup holder. Shouldn’t be a problem installing in the summer.
Fit and finish seem to be good from what I received.
