E85 and Canflex question..
mek
Mekkham
San Diego
2026 Acura Integra Type-S
So I've been thinking about doing e85 to the Type S. I use to have an Evo 10 that ran e85 for 2-3 no issues. On the Evo it was super easy btw. My question is it that same with the Canflex e85 on the ITS? Can I run whatever "E" ratio I want and the tune will work with whatever I put in? Is it just a matter of getting the canflexs, injectors, and tune? I do have flash through phearable. TIA
strtsol1109
Robert
Cincinnati OH
24 ITS, 16 C7 Z06, 24 RDX aspec, 25 blazer RS EV
yes and no, you'll need a HPFP to run full 85. E 40ish is where I think the stock stuff maxes out.
Might as well get a turbo too to maximize what the E can do as the stock turbo can only push so much.
  • Like
Reactions: mek
madchiller
Chad
DFW, TX
'24 ITS, '25 Pilot TrailSport
the canflex will adjust based on the ethanol content on the fly, no input from you.
you don't need injectors to run an ethanol tune. the stock fuel system can typically run up to E30ish. i'm on the phearable stage 3 and the tune page says it makes 400whp/400wtq and says to limit to E30. if you go higher than recommended it's possible you could lean out in the higher RPM and that's not good.
mek
mek
Mekkham
San Diego
My goal is to hit 400-450hp safely. I'm only at 3k miles. Maybe I'll go the turbo route. Running "E" seems to be a bit risky and has too many variables.
madchiller
Chad
DFW, TX
i've run it for a while. nothing risky about it just do your research. all it takes is the flex sensor, a tune, and a few bolt-ons to get the most out of it.
ethanol has a lot benefits and i'd say the biggest con is the gas mileage as you're using 30%ish more fuel. makes a lot of smiles tho.
mek
mek
Mekkham
San Diego
Can I run full e85 on a full tank? Or does it have to be a certain percentage? and the canflex will adjust to what percentage is in the tank?
madchiller
Chad
DFW, TX
with an upgraded high pressure fuel pump and some bigger injectors you could. stock stuff will cap out around E30ish but still makes quite a noticeable difference.
Wolfman
Dalton
San Diego
2024 Integra Type S, 2024 Model 3 Dual Motor
When I talked to one of the Hondata guys, he said you can run full e85 but on the stock fuel system it would limit the amount of timing/etc. My understanding a full tank of e85 would still be treated as a E30-40 blend to keep the engine safe. The benefit is if you had to run 91 you can do it without changing anything.
mek
mek
Mekkham
San Diego
So the increase is definitely noticeable? Im on a phearable tune right now and the car's pretty quick.
strtsol1109
Robert
Cincinnati OH
Im in the middle of the remote tuning currently to go from 93-E30, ill let you know once im on E
madchiller
Chad
DFW, TX
i would not run full e85 on the stock fuel system. your stock injectors cant flow that much volume and you'll lean out or at least throw a code or worst melt a piston or throw a rod.
full disclosure: im not a tuner but i did sleep last night in a bed.
SKINNIE
DFW TX
ISF, 23' BB FL5
Stock fuel system maxes out at around E30. I wouldn't go higher than that.
mek
mek
Mekkham
San Diego
What's the difference between the PRL flex kit and the Hondata? Does the PRL really show the e85 percentage on your phone? Hondata should have a gauge that tells you what you have in the tank.
strtsol1109
Robert
Cincinnati OH
Hondata does and it will show on phone and on carplay.
Drob (IMW) also has an online calculator
madchiller
Chad
DFW, TX
i've always seen the PRL kit as a FK8 thing whereas the CANflex is more for the FL5 but i'm sure they can be interchanged. the Hondata Complete app lets you see it on your phone and the CarPlay is very meh with just 5 sensors max and it's just text based.
