E85 and Canflex question..
mek
mek
Mekkham
San Diego
2026 Acura Integra Type-S
Just got my Canflex kit will probably get it install this weekend. My question is..is the flash from Hondata the same as what phearable offer? I dont want to pay $325 for phearable if I can flash with a "Hondata e85" flash and get the same result but if phearable is better then I'll go with that.
strtsol1109
Robert
Cincinnati OH
24 ITS, 16 C7 Z06, 24 RDX aspec, 25 blazer RS EV
id get a custom tune, every car is different.
BUT theoretically they will work.
@JesterTuned is around that same price point for custom tune and logging.
mek
mek
Mekkham
San Diego
Not familiar with Jestertuned, how is their custom done?
strtsol1109
Robert
Cincinnati OH
Just logs and revisions back and forth, pretty simple. Theres a thread on here with all his info if you search his name.
madchiller
Chad
DFW, TX
'24 ITS, '25 Pilot TrailSport
not even close. the phearable stage 3 will get you to 400whp on e30. you can flash the hondata e85 tune just to ensure you set it up properly. i'd def say you are leaving a lot of table without getting a custom or stage tune.
mek
mek
Mekkham
San Diego
Just got done installing the Canflex, will finish the flash tomorrow. Took her out for a drive and everything seems normal. My question is I have the Hondata app connected with the ethanol gauge loaded but it still shows zero. If everything is connected right shouldn't it read 10% enthanol? Or do I have to finishing with the flash before I get a reading?
madchiller
Chad
DFW, TX
it will show 0% until you flash an ethanol tune.
mek
mek
Mekkham
San Diego
Appreciate the quick response!
As I'm reading through the Phearable instructions, its asking for the plugs to be gapped at .022. It's already at .026. Is .04 going to make difference if im not going crazy with the tune?
madchiller
Chad
DFW, TX
this is so you dont get 'spark blowout'. at wide open throttle if the gap is left too large the incoming air/fuel will drown out the spark giving you a misfire. if you misfire enough you could really mess something up.
you can buy a spark plug gap tool on amazon for really cheap or just stop by your local o-o-oreillys and grab one. im a novice myself and i did it pretty easily.
mek
mek
Mekkham
San Diego
Got it. Thanks
mek
mek
Mekkham
San Diego
Finally was able to flash with phearable canlfex tune. Everything went smooth...kinda. I added a PLM downpipe with an extended o2 fouler and now im getting a cel. Pretty sure its from the downpipe but when I ran the diagnostic on the Hondata app it doesnt state there's an issue with the downpipe. Hopefully it'll go away after more driving.
madchiller
Chad
DFW, TX
i didnt need to do this with my RV6 catted downpipe but i believe you need to disable the 2nd o2 sensor.
Miscellaneous Parameters -> DTCs and uncheck the corresponding Bank 1 Sensor 2 error codes
mek
mek
Mekkham
San Diego
Wait I can disable it myself?? More info please. Do I use Hondata flashpro on my laptop? Does it matter if its a phearable tune?
madchiller
Chad
DFW, TX
just google 'flashpro disable secondary o2 sensor' - its just a box you check, save the tune file again, and then reflash the car.
mek
mek
Mekkham
San Diego
Just found out the phearable tune is locked and needs a password🤬
