Cannot clear parking assist and brake assist warnings!
BlackDTeggy
Ben
2023 MT Aspec Integra/ 2006 Acura Rsx Type S
Hello ladies and gents. I recently pulled my front bumper to replace the lower grill that was damaged, as well as install a front lip. I stupidly turned the key to ignition while the harness’ were unplugged, and now I have the parking assist and low speed mitigation braking warnings.
I purchased a kingbolen Soloscan Bidirectional scanner made specifically for Honda/ Acura; and read it would take care of these codes. The scanner did pull up parking assist error, but when I cleared it nothing happened. Also can’t seem to get into BCM function which I read you were supposed to be able to- so I can’t even attempt to clear any brake codes. Any idea what I need to do here? Without going to dealer.
not really planning on buying an expensive scanner when I read this $80 just for Honda and Acura has full functionality that would need. Maybe I’m just missing something, pretty unclear directions.
acurax
I think this is the issue, the Soloscan lacks CANfd and Forward Collision Avoidance (FCA) support.
Acura Integra Cannot clear parking assist and brake assist warnings! 1789140172192-3d
That said, I have a TOPDON RLink J2534 and it works with iHDS to clear these codes.
slowcountry
Dylan
Arkansas
When you start the car with systems unplugged it throws tons of errors on your dash. These should just clear after a drive cycle. They're not engine codes that require a bidirectional scanner, it's a more of a systems warning.
The same thing happens when your car goes in limp mode due to heat or boost leak or similar.
Cold start the engine (don't let it warm up) and drive for about 10-15 mins and it should be gone.
If you have a tune, you can just reflash the tune
BlackDTeggy
Ben
I have driven multiple trips with no reset unfortunately. I’ve tried unplugging battery for 30 mins as well.
slowcountry
Dylan
Arkansas
I can never get it with the drive cycle either so I usually just reflash the tune.
Curious though.. did you double check the harness clip at the top center of the bumper? It's a small one. Should be 5 harness clips in total
BlackDTeggy
Ben
Yes, I’m not tuned. I for sure plugged the middle bumper harness, as well as the 2 on each corner for a total of 5.
slowcountry
Dylan
Arkansas
Dang, pretty much out of ideas. I've had the same issue 3 times - once from boost leak (limp mode), once from not plugging in the MAF harness, and once from not plugging in the throttle pedal harness.
But if its the Christmas tree dash from a harness not being plugged, full ECU drive cycle should clear it. Threw my experiences + your issue in AI:
This is the Full ECU drive cycle
Acura Integra Cannot clear parking assist and brake assist warnings! Screenshot_20260912_084129_Googl
This is the capacitor discharge process
Acura Integra Cannot clear parking assist and brake assist warnings! Screenshot_20260912_084443_Googl
This one has never done anything for me
Acura Integra Cannot clear parking assist and brake assist warnings! Screenshot_20260912_084107_Googl
Would love to hear how you did it once you get it to clear! This is the scanner I have for engine codes, but i've never gotten it to clear the dash/systems errors (or I just don't know how to use it for that). https://a.co/d/047yC6eq
Here's how it says it should be used for that:
Acura Integra Cannot clear parking assist and brake assist warnings! Screenshot_20260912_085327_Googl
The front parking sensors is a “closed” system, if one goes down they all go down. If you have an active code for them and then plug them in, a key cycle will have it be a stored code and remove the warnings on your cluster.
Double check they’re connected. Unless you had this issue prior to you removing the front bumper which I don’t think you did, its doubtful a sensor crapped out on you (though not impossible). So it’s either a connector is not fully seated, pin fitment was fucked up, or a tear in the harness. I’ve seen it happen where people are attempting to remove the bumper and it pulls the parking sensors pins out the connector due to wire tension from pulling the bumper too far out without unplugging the connectors.
BlackDTeggy
Ben
Could everything still be plugged in properly but it’s still storing a hard fault? I’ve ordered a Launch creader 3.0 for Honda which is supposed to do all of the reinitializing sensors and brakes and what not. I will post if this doesn’t clear it- if not then off comes the bumper again 😡
A key cycle and a battery disconnect/re-connect should have been enough to clear the fault. The only time it will stay a hard fault is if it’s a permanent code which will clear after a while on its own once the permitters to clear the code are met, then it becomes a stored code.(aka the module reads the sensors connected).
BlackDTeggy
Ben
This is what Google says. I’ve tried the battery disconnect, can’t say I’ve gone on 3 specific drives they are describing. So I guess I can try that, waiting on scanner to get here.
Acura Integra Cannot clear parking assist and brake assist warnings! IMG_1908
slowcountry
Dylan
Arkansas
I only had a "permanent" code on a boost leak issue - i fixed the issue but the code wouldn't clear for a month or so of normal driving.
I typically let the car idle to operating temp before driving in the morning - this is why the code wasn't clearing. After finding out you need a cold start drive cycle, drove to/from work 2 or 3 times without letting the car warm up at all, and the check engine light from the permanent code cleared. There was about 9 hours of the car being off between these drives.
Different issue, but suspect that ya need the same clear.
Note: bidirectional scanner could not clear this
BlackDTeggy
Ben
Yep launch creader elite 3.0 couldn’t do it, and it needs initialization that I couldn’t find. I never really let my car warm up before driving lol. Thinking dealer at this point ughhhhj I do have a dash rattle for them to check at the same time 🫠
BlackDTeggy
Ben
Follow up, I took to calibration specialist. I really fucked it up more trying to do stuff with the launch creader. I was trying everything to try and get it to reinitialize the parking sensors- ended up going into the windshield camera aiming setup which Google stupidly said to try and go into- and it deleted the calibration. He also found after all this that a parking sensor was unplugged. Not any of the harness’ from removing the bumper. But an individual sensor. I’m thinking when the grill got swapped it knocked one, but wasn’t even on my radar as I didn’t even touch any of the sensors, super irritating. So $700 later I’m back to normal. The dealer wanted 1650 all said and done to recalibrate everything. What an absolute joke…and lesson learned lol
