Adding memory drivers seat
4Dparadox
Integra Aspec/Tech Manual
Have you reached out to Mikstore via Facebook to see if they may have run across you issue before?
I got them to work again by swapping out the driver switch , rear passenger window switces and swapping out the rear window motors is the long story short. After long back and forth and delay with shipping
bandit81
bandit81
Angelo
Columbus, Ohio
I just revisited this with a chat session with Gemini. Looks like the only custom part we would need is a T harness to go between the Type-S plug to the A-Spec seat, and then connect /splice 5 new wires into the car wiring. Alternatively we can get a pigtail from a A-Spec w/ Tech seat and back up or repin our Type S harness (if the same).
A doner drivers A-Spec w/ Tech seat should have everything we need for the swap otherwise.
We need to confirm the connectors between the A-Spec w/ Tech seat are the same as the Type-S. That will help us making the T-harness. One other option, if the harness is exactly the same and the wires are bare, we may be able to simply add 5 wires to the existing harness. Confirming the connectors may make this step easier.
Door side of things is easy, we just need to swap out the door wire harness, power window switch, and add the seat memory switch.
bandit81
bandit81
Angelo
Columbus, Ohio
By the way, the 2027 Integra Type-S now includes the memory seat option as well as mirror adjustment found on the A-Spec Tech. If you are about to buy a 2026 Type-s, this is something to consider. It appears the red stitch interior is going to yellow, not sure I would want that color change with my blue exterior ITS. Hopefully the yellow stitch is for the limited edition only, which with the car painted yellow is pretty sweet.
The black HVAC controls in the 2027 look sweet too.
acurax
I think the yellow stitching is across the lineup based on how it wasn't listed a specific to the Heritage Edition.
You can get a set of gloss black HVAC controls here: https://www.integraforums.com/forum...rol-knobs-from-strix-fits-all-integras.62413/
bandit81
bandit81
Angelo
Columbus, Ohio
