6MT stock clutch longevity
KPrower
Memphis
Just crossing 50K miles on my 2023 ASpec with the 6MT. Curious how long the factory clutch is lasting for folks?
UWU
colorado
type s
The clutch is a consumable item. If you occasionally drive like an asshole. You can expect 50-120k miles. Sorry for how crazy that sounds but there’s so many variables. Are you tuned. Are U tracking. Etc
my son has a 10gen si. Bolt ons and tuned since almost day one. The clutch began to slip around the 20k mark iirc. He doesn’t track but does hit canyons locally every spring and summer. He did the thing that allows him to fit the k20c1 clutch. Even with his turbo swap and stronger bottom end. It’s holding fine. He’s at about 70k miles
KPrower
KPrower
Memphis
Not tracking occasional spirited driving not tuned. I’ll have to look up that clutch modification. Thanks for the tip.
UWU
colorado
type s
Your clutch should last a good while then
one thing I thought of. The clutch delay valve. It seems to put the clutch in a position to take a little more abuse vs the trans? That could be a variable too
UWU
colorado
type s
That doesn’t sound like fun at all. It’s like those people that want their brake pads to last 70k miles so they use the brakes gingerly
the clutch is a consumable item.
also. Half of us don’t know what a kilometer is. We know it’s a thousand meters. But wtf even is a meter? Our country develops true stealth on our fighters and bombers. We use the superior imperial system here šŸ˜‚ we don’t use that one system that has no clout
Never replaced a clutch on a MT car. Been keeping them for ~20 years and 200k km.
What are your best practices for such longevity? I daily my car and put about 10k a year on her. Once in a blue moon I’ll drive spiritedly but have never dumped the clutch or anything like that; just pulls onto the freeway and stuff like that when I’m already rolling.
UWU
colorado
type s
Keep boost in the negatives before pushing the clutch in. Should ensure tq is at its lowest. Keep upshifts no higher than maybe 3k rpm. Don’t start a downshift till you’re at least at 1200 rpm. Again, the point is to keep tq at its lowest
Roger that; easy enough! Can’t say the folks behind me will be happy, though šŸ˜… tri-state drivers have zero patience
UWU
colorado
type s
If I can be real with you. Maybe try thinking of the clutch like brakes. Very very expensive brakes šŸ˜‚
so what if you don’t get 10 years out of it? At least the fun will be worth?
Just don't make it slip. And be gentle. That doesn't mean you can't have fun! I've done some racing with my previous cars!
Worst case, if one day your clutch is gone, then you replace it. A bit costly, but not the end of the world.
There have been a few times where I’ve accidentally gave (possibly) too many revs while holding at the bite point, say, upshifting from 1st to second specifically. Just kinda a boggy sound and lull until the revs dropped and the clutch caught and got me going. I’ve never smelled any burning or had any issues though. Likely to say it’s okay to occasionally do that; accidentally of course.
That’s how I’ve always thought of it. It’s meant to be a wear item but wanted to balance ease of drive and longevity for sure. Worst case; fk8 retrofit w/the exedy clutch will be inbound which will make it sting less if/when I do replace 😜
UWU
colorado
type s
That’s what my son did on his 10gen si coupe. Even the w2 turbo swap doesn’t challenge it.
boosted_canoe
'23 Civic Si
clutch can last 200k+ miles if you don't slip it too much at high torque. hell, I've heard of people going over 300-400k miles on original clutches. it's very driver dependent. If you are careful to only slip the clutch at low loads, it will last a long time.
