Grelco
'24 Integra Type S
Does anyone know what the offset on the stock wheels is?
wontondon
Ontario, Canada
DE5, MK7 GTI
Both the Civic hatchback and Integra are 18x8" +50.
FL5 CTR is 19x9.5" +60
Given that the dual axis suspension is lifted from the Civic Type R…best guess for ITS would be the same.
Could be completely wrong.
TeggyS
PNW
F150
is there any official information on the bolt patterns? I have seen 5x120 and 5x114.3 floating around.. I’m hoping it stays at 5x114.3 since I already have some wheels in those bolt patterns
Grelco
Grelco
'24 Integra Type S
That's what I was thinking, and I think if so the ideal winter tire size would be 18x8 +42 and 235/40/18 tires.
However I also read that the ITS is 0.4 inches wider than the CTR, and can't find the true wheel specs anywhere. I'll update this thread with any info I find.
wontondon
Ontario, Canada
DE5, MK7 GTI
If it's using the same brake hardware as the CTR it'll be 5x120.
Grelco
Grelco
'24 Integra Type S
Correct, according to TireRack (ITS is a selectable model on the wheel/tire builder now)
For those interested:
Acura Integra Type S Winter Wheels / Fitment Specs Screen Shot 2023-05-16 at 3.45.07 PM
Acura Integra Type S Winter Wheels / Fitment Specs Screen Shot 2023-05-16 at 3.46.24 PM
wontondon
Ontario, Canada
DE5, MK7 GTI
Been debating this one in my head. 18x8 +42 would match stock wheels for where the outside face sits, but would also change the scrub radius. Thinking you need to maintain +60 offset regardless of wheel width to maintain scrub radius - this becomes a challenge as there's virtually no wheels with such a high offset.
Hoping someone with more knowledge can chime in on the above and how to maintain scrub radius/handling characteristics when modifying wheel width.
Grelco
Grelco
'24 Integra Type S
That's a good point, and this is going to be a challenge. I haven't found anything bigger than the +42 ones I posted.
Estoril
Chevy SS, 4runner
The type R forged accessory wheel would maintain scrub R, drop ~20 lbs in unsprung and you could easily swap in acura center caps to look oem. Still 19" though
Yeah. I don't care for the design though.
Also arent the factory ITS wheels lighter then the 18s on the standard Teggy A spec?
Lflouie
Jeff
TN
AUDI S4, Alfa Romeo Giulia QV
The CTR and ITS will be sharing the same bolt pattern circle and bore size, and suspect the same offset.
The suspension knuckle was designed to overcome torque steer by the relationship of wheel and centerline of the suspension, changing offset is a key factor that if changed may reduce the effectiveness of the design. Doesn’t mean that it is a disaster or a few mm change ( 5mm) but large changes (20mm) could lessen its effectiveness.
Grelco
Grelco
'24 Integra Type S
The suspension knuckle was designed to overcome torque steer by the relationship of wheel and centerline of the suspension, changing offset is a key factor that as it is change may reduce the effectiveness of the design. Doesn’t that it is a disater for a few mm change ( 5mm) but large changes (20mm) could.
I haven't found anything in 18x8 or 18x9 that's close to +60, but the CTR forums seem to mostly say going to +42 or so (which seems to be the biggest off the shelf number) does change the handling a bit but it's "not a big deal."
That may or may not be true, but I'm not sure we're going to have much choice for winter wheels without buying custom ones.
wontondon
Ontario, Canada
DE5, MK7 GTI
Enkei has a couple 18x9 +50 options. That's as close as I could find without going custom/forged.
