Sport+ Exhaust Pops not working
Rz2Gd
Nate
North Mankato, MN
2025 Acura Integra Type S
Today when I drove my ITS, I had it in Sport+. After driving for maybe about 10'ish miles or so, in local city streets and highway, I noticed that at no time, was there any exhaust "Pops" occurring. I had plenty of situations that should have produced them, such as downshift decelerations and/or clutch press engine falloffs.
Normally this not only opens the exhaust for the more audile notes, it generally will exhibit the exhaust "Pops". I understand that the system won't do it immediately. It seems to require the entire system warm up a bit before this behavior is exhibited. I also understand that not everyone prefers these noises, citing them as "immature". I tried adopting that mindsight myself to just run the exhaust in Sport. Unfortunately, I seem to really enjoy the Pops and therefore run Sport+ and/or Individual mode where I have the Engine set to Sport+ mode.
This is the first time since ownership I've experience this issue. Mine's a 2025 model and I've had it for about 1 year now.
One thing to note is that I recently replaced the OEM air filter with a K&N drop in filter (did not change to a Cold Air Intake, just replacement filter in standard airbox). I'm sure many may take issue with that choice as I've noticed in the past using those filters as replacements can be controversial and contestable. I have had years of success and observed reliability with most of my other vehicles running either drop-ins or full airbox to CAI swap outs. That being said, I've been driving the car since that replacement and observing the "Pops", and therefore am somewhat skeptical as that being the cause. Of course I tossed the previous filter to swap back and confirm this.
Do I need to be concerned?
If the issue persists, am I going to have any success with the dealership service department, in explaining, them understanding, and accepting the issues as legitimate?
I only ask that prior question because past experiences with dealership service departments in general seem to have issues with models or trims that are outside the normal higher volume sold models. As an example, I had a 2005 Toyota Corolla XRS with the 2ZZ-GE. It experienced a issue the valve timing. The dealer attempted to repair, but upon receiving back, the VVTL-i system no longer worked. When I confronted them about it, they basically indicated they didn't understand this engine due to the lack exposure their department had with the engine being it was more rare than a standard model.
Old_Dad_Actual
Cincinnati, Ohio
2025 ITS
Do you have anything to pull codes? I haven't experienced it myself, but I've heard you can have a soft code (i.e. no CEL displayed) that could cause the loss of the pops & bangs.
You have an active or pending code. Clear it and pops will be back.
I have a K&N filter and this has no effect on the pops & bangs.
Rz2Gd
Rz2Gd
Nate
North Mankato, MN
Ah good suggestions. I do have a decent code reader (don't remember the model exactly, but it's not a cheap $20 model). I sort of removed that possibility from my mindset as when I bought the car the dealership assured me none of my tools would work with this car, that I'd need to pay for some software to interface with it. Again, I was skeptical of their claims, but still kind of removed the idea from my mind. I'll check and see and report back.
This has happened to me under very specific conditions. more than likely you have a "ghost code" that'll say there's some sort of low voltage detected. there would be no check engine light on the dash. clear this code by putting the car into accessory mode, clearing the code, turn the car off, then turn the car back on. after the car is fully warmed up (4 bars), you should have the pops and bags back.
Old_Dad_Actual
Cincinnati, Ohio
2025 ITS
That's just something a scammy dealer will say to make sure you always come to them if your CEL comes on.
East Coast
ive had this happen a couple of times, ive always cleared the codes with my own reader and they come back. once was for the emissions thing, and the second time was for the idle control valve or something.
keep in mind that while you're driving the pops and bangs will occasionally stop for a minute or so at a time before they resume (as far as i can tell this is normal for everybody) but that usually happens after driving for a bit. if the car doesn't immediately produce the pops and bangs once it reaches operating temp, then something is wrong.
Rz2Gd
Rz2Gd
Nate
North Mankato, MN
This is what I'm seeing. Haven't looked into it further. Just did the check over my lunch break. Description seems very concerning though. Besides the pops issue, car ran fine otherwise this morning when I drove it.
Acura Integra Sport+ Exhaust Pops not working 20260407_124300
East Coast
did u get the string of warning messages on startup about rev matching, cruise control etc etc being disabled or whatever? it's like a whole slew of various systems that get affected by it. i'm pretty sure all of us with these cars have gotten it at some time, typically pretty early in the car's life. i got mine at 4 - 5k miles i think.
either way clear the code and drive it for a bit for everything to reset. if it comes back i would take it in for servicing. they never came back for me.
Old_Dad_Actual
Cincinnati, Ohio
2025 ITS
Not serious unless it comes back, which is why it's pending...it's waiting to see if it throws that code again. I think the evap stuff is usually related to leaky gas caps/fuel filler necks, etc. I dealt with an intermittent one on my wife (and eventually son's) Equinox. I'd recommend clearing it and driving for a while to see if it comes back. Might just be an anomaly.
East Coast
i forgot we didnt have gas caps for a second lol. when my car threw all the emissions systems warnings i cleared the warnings by jiggling the inner gas flap with my finger lol. i still had to clear the codes with a code reader though
Rz2Gd
Rz2Gd
Nate
North Mankato, MN
Clearing the code did bring back the Pops. Yes, I checked the gas tank flap to see if it was obstructed some how. It wasn't. So unsure how that code was determined.
Thanks for the help. I appreciate it.
Don't forget the inner flap. I've had that one get stuck when filling up with a vp type can. Actually had the nozzle stuck in there... They throw evap codes.
These evap codes are actually not uncommon in capless systems. The little spring mechanism doesn't always seal 100%. We just notice more because of the lack of pops...
