Hondata
Hondata
Elite Sponsor
Torrance California
www.hondata.com
23' Type R,22' Civic Si,18' Accord 2.0T,17' FK8
Many of you know what Flex Fuel is, but just as many do not. So, a little more education is warranted.
By the way, the CANFlex systems are flying off the shelves. Thanks for the support. We hope to see your reviews soon. Its pretty quick to install.
Software installation is easy. Select your vehicle, then the 49 state calibration for a stock fuel system or a Hondata Fuel System. View attachment 246807
Acura Integra CANFlex What is flex fuel 49 state calibration select screenshot
JesterTuned
FL5 Type R, S2000, Ram TRX
Thank you again for the awesome product! Looking forward to testing it. I already have 3 kits lined up to tune on full fuel systems and bigger turbos.
Hondata
Hondata
Hondata
Elite Sponsor
Torrance California
www.hondata.com
All you need to remember are two numbers. The numbers three and four.
  • 3 Gallons E85 to 4 Gallons pump = E40
  • 3 Gallons pump to 4 Gallons E85 = E50
This gives you an excellent balance of range and performance.
I have a question about the tune running an ethanol blend. What I am thinking is that I will not always be able to get a blend depending on location and sometimes it will be straight 93 octane. Do we need a custom multi-tune so for example settig. 5 will be for ethanol mix and setting 4 will be regular 93? I am sure the content analyzer plays into the ECU calculations but I am wondering if we get it tuned on ethanol is that tune still safe when running 93 only? I am new to flex fuel so inquiring.
@JesterTuned @Dereck
Got ??
Acura Integra CANFlex What is flex fuel 202408241
JesterTuned
This is the beauty of the CanFlex kit. It requires no map switching. The car will self adjust to the programmed settings on the ethanol tables. Essentially acting like on the fly map switching.
You still have access to the regular map switching but in my opinion it is even more convenient on the canflex since it does it on the fly.
Hondata
Hondata
Hondata
Elite Sponsor
Torrance California
www.hondata.com
Your car is safe on everything from 93 to E85. The calibration provided and indicated in this thread adapts and changes automatically for whatever ethanol level you have in your tank. A reputable tuner could make more power but the supplied calibration is conservative to protect your clutch.
Thats a cute rule but dosent apply in my area. E85 ranges from station to station. So depending on what station I will have to calculate. Some are high 70% other are in the 60% levels. Then if i switch and just run 93.. so yeah having that calc would be Handy in your app. Also will you be adding additional screens to it since its currently capped at 3?
integra__gang
Eddie
Las Vegas
‘24 integra Type S, ‘97 Integra LS, ‘95 integra SE
What is the difference between the 49 state CANflex and the regular CANflex?
integra__gang
Eddie
Las Vegas
There is only one product. The 49 state SEMA certified CANFlex.
I meant in the hondata base tune options, there’s two options and I’m not sure what the difference is.. one says 49 state e80 and the other one just says e80
Hondata
Hondata
Hondata
Elite Sponsor
Torrance California
www.hondata.com
The E80 calibration is tunable. The 49 State calibration is locked. Other than that they are the same. February we will have the Integra 1.5 calibrations released. We expect the performance to be similar to the 22 Si and 22 EX/touring.
