Acuity shifter was finally released!
edido
ITS (TEP)
Installed mine today.
The process wasn't too bad. Acuity's instructions are pretty good (their process is based on the Civic; there are a couple differences re: trim for the Integra). ...scratched my hands a good bit, but that's to be expected, haha.
Any watch outs that you can share? Plan to install mine in a couple weeks.
Move the driver's seat all the way back before disconnecting the battery (also recommend moving steering wheel all the way up and in, but you can do that any time).
You don't have to disconnect the climate controls from the cable harness (you can just set it aside).
I ended up taking the shift boot off the piano black console trim, because I couldn't get at the tabs to disconnect the console wiring harness from the "white clip" -- I believe this is due to slight differences between the Civic / Integra.
You'll need to disconnect the leatherette trim on the passenger side before taking the center console out. Just pull it straight back.
Center console upper trim has a screw (passenger side / upper right) behind the leatherette passenger side trim piece -- also unique to the Integra.
Careful not to lose 2 of the center console screws (the middle pair -- there are 6 total).
Any chance it can be done through the hole in the console without removing the whole thing? I was able to do base bushings that way. Small hands are good for some things.
I think you'd struggle to do the cables.
lmtlsauto
Elite Sponsor
LMTLS Auto
shop.lmtlsauto.com
2023 Honda Civic Type R
Have you tested it?
Can you widen the side to side gear spacing with it?
As stated above yes the gate spacing is adjustable.
I ran the prototype in my FL5 for the last 6 months and I can tell you it's a great upgrade. The adustibiltiy to fit your driving needs is second to none.
