Sound system build progress thread (warning: will be slooooow)
ashmostro
Northern VA
2025 ITS
Yo.
So I hate the SQ of the factory ELS system. It sounds muddy, unbalanced through the frequency range, the imaging sucks butt (even in Neural Surround mode), blah blah blah.
Things I wanna do, not necessarily all at the same time:
  • Sound deaden the doors, door cards, trunk floor, and inside of the OE subwoofer enclosure
  • Integrate a DSP amp in, likely an Audiotec-Fischer MATCH UP 10 DSP. I will have to build my own T harness for the amp since none exist on the market. The amp will likely mount under the passenger seat, given the dash location of the factory amp.
  • Upgrade the front door and center channel speakers, the rear C-pillar speakers, and the subwoofer. The MATCH amp will drive all these speakers. I have not yet determined if the front door/A pillar speakers are all on their own channels or running off a passive crossover network (if you know, please respond here!)
  • I will disconnect the front roof speakers and rear door speakers. They are over complicating the sound quality.
My current top choices for the replacement speakers are:
  • Front door woofers: Hertz C 165L 6.5" cone, chosen for optimal Qts and dispersion up to a 900Hz lowpass point
  • Front door midranges: Dayton Audio CF50N-4 2" dome, chosen for excellent dispersion up to a 2.8kHz crossover point
  • Front A pillar tweeters: Dayton Audio CF18N-4 3/4" dome, chosen for excellent dispersion
    • Edit - going with the Peerless OX20SC00-04 instead
  • Front center channel: Dayton Audio CF50N-4 2" dome (bandpass 900 to 2.8kHz)
    • Edit - going with the Faital 4FE42 4" cone midrange instead and can run it down to ~300Hz in that position
  • Rear C-pillar midranges: Dayton Audio CF50N-4 2" dome (bandpass 900 to 2.8kHz)
  • Rear subwoofer: Rockford P3SD4-8 (already proven to work well in the stock enclosure)
As implied, the crossover points are:
  • Sub: infrasonic to 80Hz
  • Woofers: 80Hz to 900Hz
  • Midranges: 900Hz to 2.8kHz
  • Tweeters: 2.8kHz to ultrasonic
Whether I use passive crossovers (which I will build and have already designed) or active depends on the factory wiring of the front door and A pillar speakers. If they are each their own channel (which they probably aren't) then I will go full active, which is my preference. Heck, I might even run my own wiring if they aren't, given the HUGE advantage that time delaying such a setup affords.
Any fellow SQ-heads in here? Thoughts?
-Ash
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765746844005-bc
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765746870391-sj
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765774718575-j
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765772588063-h5
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765746921893-vl
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765746945807-l4
ashmostro
ashmostro
Northern VA
2025 ITS
Oh and here's the front stage passive crossover if I'm forced to go that route:
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765747116182-s
ashmostro
ashmostro
Northern VA
2025 ITS
Update: I'm also considering the Peerless OX20SC00-04 tweeter for a much easier installation since they could just be glued into the existing locations without having to build and finish a flange. I don't like the frequency response as much but EQ can fix that.
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765772060917-ec
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765772072777-9i
ashmostro
ashmostro
Northern VA
2025 ITS
Aaaand another change.
The Dayton dome midrange won't do well in the center channel location as a voice speaker (I will have it set up to only output for infotainment interactions).
I'm going to go with a Faital 4FE42 4" cone midrange instead. It has the added benefit of being a wideband so I'll get better top end extension than with the Dayton (not that it's needed for voice, but it's a free bonus).
Acura Integra Sound system build progress thread (warning: will be slooooow) 1765774541222-b0
