Screen Protector?
RRP RSX-S
2013 Mustang GT
Has anyone used one on the infotainment screen before? There are a ton available on Amazon for dozens of different car models.
I like the idea of it. Makes for an easy wipe down. My screen on my 22 Bronco Sport has super fine scratches when the light hits it a certain way from the dealer wiping it once.
But I’m wondering about car heat and the adhesive. Do you think it’ll just slide off one day leaving goo on the screen?
I’m looking at this one currently. Seems to have the best reviews. Some of the others have fitment issues on corners. They make one for the 7” and 9” screens.
Screen Protector Film for 2022 Civic 11th Generation (9In) https://www.amazon.com/dp/B099FDHBGP/ref=cm_sw_r_cp_api_i_A139W32F8H7N5H22GGPD
Decks515
2023 Acura Integra A-spec 6mt
I put one on my 19 Silverado and loved it, cleaned up without worrying about scratching it, and strangely enough it did add a nice glossy look to the screen. Had no issue with touchscreen function, and in the Florida heat and humidity it stayed on with no problems.
I did worry because there was a gap between the radio and the trim that it could fall into on that truck, and I was terrified if it fell I'd break it and cut myself getting it out. I also paid between $15-$20 for it, and I'm sure there are probably better and not so good ones available.
I also worry a bit because some things use the touchscreen to dissipate heat, and putting a thicker cover on it could affect it. However, in a car, it's either screaming hot from sitting in the sun and off, or typically climate controlled with AC or at least open windows when running
RRP RSX-S
RRP RSX-S
2013 Mustang GT
That brand was my second choice. But several reviews said the corners weren’t cut right and stick up from misalignment. Also the hole cut outs for the buttons on the left were off a bit on many of the pictures even though the protector was as far as it could go to one side.
The one I linked in the first post is what I ordered and the reviews say it fits perfectly and the hole cut outs look good in the pics.
Did you install it yet? I just ordered the screen protector and it should be here tomorrow. Im still rocking the factory protector
RRP RSX-S
RRP RSX-S
2013 Mustang GT
Don’t have her yet :( It’s built, just waiting on transit.
But let me know how it goes on.
Will do.. man this thing drives nice. Not sure if more than 200hp is needed since it's already hard to keep it at the speed limit.
stellarrock
2023 Integra Had: 2018 Civic Type R
A heads up for anyone thinking about getting a screen protector, DO NOT buy the "Moonlinks" one for the 11th gen Civic from Amazon. It fits fine, but the adhesive is defective. It's only been 2 weeks since install and sections are already unpeeling and creating small pockets underneath.
I picked up the one you mentioned but it won't stay stuck on the lowe 1" of the screen. Creates a huge air pocket there.
IntegraAgain
Triad NC
RRP RSX-S
RRP RSX-S
2013 Mustang GT
I’m having the same issue in the same spot. It fits and feels great. But that bottom edge doesn’t like to stick. I’m order another to see how it does. End of the day I guess it’s still better than none.
True.
