Replace rotors or not? Two track weekends and 12.5k total miles
Ronnie M.
Spring, TX
I have a set of Paragon P3 brake pads ready to go before my next track weekend in November... I have done two track weekends so far with The Driver's Edge. I only turned VSA off for a couple of hard sessions, since it was a new track I had to learn each time. I wonder if the rear rotors are cooked or not.
I haven't owned any car this new and modern in a long time - wondering what the consensus is, and how to properly analyze and maintain this car. I'm the guy who wrote this thread thinking two track weekends a year would be the ceiling for having a daily driver + occasional track use. Already seeming pretty pricey the way thing thing eats up brakes!
UWU-mancer
UWU
colorado
type s
Measure with calipers. If there’s still meat on that bone. Send it
sorry, I don’t remember what the range/thickness should be tho.
ModJPB
Jason
New Jersey
22 Civic Sport Touring CVT
12.5k miles is not much. Rotors dont wear like pads when run hard. If they are not pulsating and thickness is still greater than minimum spec. I would keep using them. No need in waisting money.
UWU-mancer
UWU
colorado
type s
This. People who drive gingerly can usually run 2 sets of pads before needing rotors
tho. The front brembo pads seem to chomp on the rotor some. They must be semi metallic? I’ve no idea if you could really truly run two sets of oem pads on the same rotor. I’m sure if they were ceramic ebc red stuff pads U definitely could?
the rear seems to use Hondas organic pads. Considering how the car eats the rear pads. Bet U can run 3-4 sets of pads back there before needed new rotors šŸ˜‚
Ronnie M.
Ronnie M.
Spring, TX
I did one long track day (5 sessions) and now I'm told my front rotors are done, or at least they won't hold up the next time. 15k total miles, still good for daily.
Brakes felt great for 4 sessions, just slapped on new Paragon P3 pads... the 5th session I had a lot of brake shudder, was it brake fade or uneven brake pad deposit? I'm told it was brake fade by the mechanic who looked at my rotors.
Anyway, I think I might upgrade for next time. Rotors only held up under 5 total track days.
UWU-mancer
UWU
colorado
type s
I’ve learned the front brembo pads beyond 300f eat the rotors like a mf! I’d just redo front and rear with better pads. The carbotec 1521 seem to have the same average friction as the brembo pads but can take a higher temp range. Tho their initial friction is a hair lower. I’m being told they modulate way better too. Maybe research those, see if they fit the bill?
for rotors. Either oem or paragon or whatever fits šŸ˜‚. If you’re tracking and you aren’t a rich mf it would make sense to be sensible without putting safety into question.
but. If you are a rich mf. Bro go get 6 piston fronts with huge rotors. F it. They’re gonna look great and I’m sure the extra thermal overhead will be nice
I have zero experience with the carbotecs btw but will be getting them on come January or February.
Ronnie M.
Ronnie M.
Spring, TX
The first 4 track days were with OEM pads, but this last one was with the Paragon P3s, so I'll probably upgrade Paragon rotors all around.
