Ash @ S2i Audio
Ash @ S2i Audio
CivicX Basic Sponsor
Ash
Northern VA
www.s2iaudio.com
The mono thing was just because of the number of amplifier channels I had available at the time. I've since upgraded to a 12 channel amp and running rear fill in stereo.
That said, the device is set up to preferentially direct rear fill to the door speakers instead of the rear c pillar speakers due to their tiny size and inability to be replaced by anything aftermarket due to space constraints.
If you do end up buying and want to direct rear fill to the C pillars let me know and I'll make a modification to your unit so that it can do that. Not a problem.
crash1340
Corie
Charlotte, NC
2026 Civic Si
Sorry for the slow response - I've been manufacturing harnesses for a large distributor order all weekend. Regrettably, I no longer have analog T-harnesses on my pipeline as I need to focus all my R&D energy into next-gen digital integration (which includes your 2026 Si).
Sorry for the bad news - the upside is that by September I will be fully focused on the A2B integration R&D once I get these orders processed. I have purchased some of the proprietary technology needed to reverse-engineer Honda's protocol and hope to be doing prototype testing by mid-Fall.
-Ash
Hey at least A2B allows for daisy chaining and nodes... I wonder if that would allow cleaner subwoofer add-ons or not, or if whole system DSP would still be needed.
Ash @ S2i Audio
Ash @ S2i Audio
Ash
Northern VA
www.s2iaudio.com
That would be very hard to do because the master A2B node has burnt-in registers of what nodes it expects to see when it wakes up. I think you'd have to reflash the master first before you can add anything that doesn't belong.
In the case of an integrator replacing a node (ie a factory amplifier) you are just fooling the system by replicating the address of the former OEM node.
crash1340
Corie
Charlotte, NC
2026 Civic Si
Man they really can't just make this simple to do, can they? We'd stop having to modify these cars if they would just give us good components and amplification to begin with, but no of course they would spend even MORE money complicating the process ...
Ash @ S2i Audio
Ash @ S2i Audio
Ash
Northern VA
www.s2iaudio.com
I mean, it's on purpose. Automakers want to lock down more and more of their systems so that they can ensure any paywall they put up can't be hacked.
It's poop.
Ash @ S2i Audio
Ash @ S2i Audio
Ash
Northern VA
www.s2iaudio.com
Mega-Announcement! We are now an authorized Arc Audio dealer!
I'm super excited to release our first PURE Digital Integrator + pre-configured DSP Amplifier kit! We will be selling these kits paired up with an Arc X2 800.8, Blackbird, or Falcon - you choose how many channels and how much power your planned system needs.
We will then reach out to you and discuss your planned system configuration and custom-configure the DSP Amplifier I/O for this setup, and manufacture a customized wiring harness for you based on the length needed and which speaker locations you plan on using. You just supply the speakers and installation accessories (like power wire, fuse blocks, etc.)
We can also sell Arc Audio speakers if you want to go that route, so contact us first if that is your plan so that we can build a custom order for you!
Looking forward to setting up your next factory-integrated high-end sound system in your Integra with ELS!
-Ash
bicycle_wreck
Knoxville, TN
2012 Subaru WRX, 2025 Honda Ridgeline, 2026 Integra Type S
For the Type S w/ELS, the PURE's routing feeds amplified/DSP'd signal back into the factory harness, and the midranges and the tweeters share channels (i.e., wired in parallel) on the factory harness, correct?
So, to run an active 3-way front stage on the Type S w/ELS, it looks like I'd need to run a separate set of wires from the amp/DSP to the pillars/tweeters, correct?
goobax
texas
2026 Integra Type S
yup, that’s how my focals are wired
Ash @ S2i Audio
Ash @ S2i Audio
Ash
Northern VA
www.s2iaudio.com
Expanding our partnership with Arc Audio, we are now also offering pre-configured turnkey sound systems. We pair high-end Arc Audio equipment with our PURE digital integrator, extracting the most out of the incredible Arc hardware.
We will build you a custom-configured full system with signal harnesses customized for your vehicle's layout. An optical cable is included, as well as all necessary speaker mounting brackets for a direct OEM-like installation, without modifying the car permanently.
Power wiring and amplifier installation accessories (fuse blocks, etc.) are not included and must be supplied by you/your installer.
You have three choices of system, set up as performance tiers:
  1. "Enthusiast" - this may be the entry point, but it's still better than most high-end factory sound systems! We set up the front stage with Arc X2 components, X2 coaxials for the rears, and a small-footprint 8" X2 subwoofer. All of this is driven by the single-chassis X2 800.8 DSP amplifier - a small powerhouse!
  2. "Audiophile" - this is where you really start to pull away from the aftermarket pack, with genuinely high-end "AS" series speakers for the front stage and fill, which are components this time in the rear. While the system is still based on the X2 800.8 DSP amplifier, a second non-DSP X2 amplifier is added for the subwoofer, allowing more power to the front stage and the larger sub. This system gets LOUD and CLEAN at the same time.
  3. "Competition" - this is for the person who doesn't want to make any compromises. The absolute best speakers are used in the front and rear, and the subwoofer is upgraded to a 12" SQ beast. The front midbasses get a whopping 250 watts each and the sub gets 800 watts. Why so much power? Dynamic range. If you want a sound system to be able to transport you to a concert environment, you need dynamic range for those moments that cannot be reproduced by lesser systems.
Enthusiast
Balanced SQ
Audiophile
SQ & SPL
Competitor
A Live Concert
Front TweeterX2 1.0
(50W x 2)
AS 100
(50W x 2)
RS 1.0
(75W x 2)
Front MidbassX2 6.0
(50W x 2)
AS 600
(170W x 2)
RS 6.0
(250W x 2)
Rear FillX2 602
6.5" coax
(50W x 2)
X2 6.2
6.5" comp set
(50W x 2)
RS 3.0
3" wideband
(75W x 2)
SubwooferARC 8D2
8" SQ sub
(170W x 1)
ARC 10D4
10" SQ sub
(600W x 1)
ARC 12D2
12" SQ sub
(800W x 1)
DSP AmpX2 800.8
8ch w/ DSP
X2 800.8
8ch w/ DSP
Blackbird
8ch w/ DSP
Dedicated Sub Amp-X2 1100.1
monoblock
Nighthawk
2ch bridged
Optional Sub EnclosureSealed Box
0.45 ft3
Sealed Box
0.65 ft3
Sealed Box
1.0 ft3
The ordering process is simple:
  1. Place an order indicating which Tier you want, and whether you want us to supply you with a non-custom subwoofer box, or if you plan to make your own you can exclude it.
  2. We get in touch with you within 24 business hours and confirm your vehicle and discuss any unique configuration needs.
  3. We build the kit and pre-program the custom I/O configuration to your DSP before shipping the bundle
If you aren't sure what you need, feel free to get in touch with us prior to ordering and we will gladly advise you!
Also, we can customize! If you want something a little different than the above standard configurations, or if you want to utilize different/additional speaker locations, send us a note before ordering. We can custom-configure a system for you.
IMPORTANT NOTES:
Your DSP will still need to be tuned by your installer / yourself if you are experienced, but the heavy lifting of setting up the right I/O and analog/digital signal mixing for the car's infotainment sounds will be pre-configured, and the harnesses will arrive terminated, labeled and pre-connected for a convenient installation.
This is a custom build-to-order package so there is effort and cost involved to build harnesses, order the speakers and DSP, build speaker adapters, and create/load the I/O file for the DSP. All sales are final once orders have been placed. We appreciate your understanding.
The Acura Integra with ELS Studio also has a 3" midrange in the doors, from the factory. In order to maximize the performance of these systems, we include a 2.5" AS250 midrange for the "Audiophile" Tier and an RS 3.0 for the "Competition" Tier, only. The "Enthusiast" Tier remains a two-way front stage to keep in line with that Tier's low-cost/high-performance design goal.
acurax
2024 Acura Integra Type-S
Just a thought, but if someone was going for a sort of stealth aftermarket system, what compromises might need to be made?
For example, would it be possible to install the 8" subwoofer into the factory subwoofer location? Or, might there be a custom enclosure option that fits into the location of the original enclosure allowing for different dimensions?
Here's one example of someone retaining a OE appearance.
https://www.integraforums.com/forum...r-sound-deadening-nice-yet-inexpensive.60922/
Ash @ S2i Audio
Ash @ S2i Audio
Ash
Northern VA
www.s2iaudio.com
Good question, and yes that is doable, but I want to keep that as a "custom" request rather than a standard option (as you can see, it is possible to order the kit without a subwooder + enclosure). I can build any combination of equipment they might want, including a small subwoofer that fits the stock enclosure.
The real issue with this is that A) I don't like the rigidity of the stock enclosure, and it requires significant deadening to work as well as a prefab, and B) in some ways it's a lot more complex than going prefab, so many "convenience" users might end up experiencing the opposite.
Something I will definitely be paying attention to though. If a lot of my clients end up asking for this, then I will figure out a standard solution.
Thanks for the continued very helpful feedback! Keep it coming please :)
I'll second this. The factory box does suck and takes some strategic work to deaden. Polyfill is a must with it too. I'm okay with the results I got with the Rockford, and once I get around to installing the amp for the sub I think it'll be in a modestly happy place. Mine looks 100% oem, because on top it is.
Ash's setup will be more flexible and better. You spend the money, yes, but you're also going to get proper power per channel and a series of other benefits.
If you're not willing to spend the time and money, the way I went makes sense, but understand you're still compromising and the peaky brightness of the els can only be tuned out at one or two volume points you're okay with.
Ash @ S2i Audio
Ash @ S2i Audio
Ash
Northern VA
www.s2iaudio.com
