Power Steering Motor Replacement
AlexO
Alex
Ferndale, WA
2024 A-Spec Tech
This may be a bit of an unusual question but maybe somebody here can help.
I need to replace my steering rack after the housing cracked in an accident. The EPS motor is intact and functional.
I bought a used OEM steering rack and am wondering if I can bolt my original motor onto the new rack.
My thinking is that if I keep the original motor, there won't be a need to program the ECU to the car.
Of course I'll still need to calibrate the neutral position and sensors but I can do that with my Autel.
It looks like it should be a simple swap but wondering if anyone here has dealt with anything like this?
Thank You
Acura Integra Power Steering Motor Replacement Untitled3
Acura Integra Power Steering Motor Replacement Untitled2
acurax
Since you wouldn't be replacing the EPS motor/control unit as far as your car's ECU is concerned these post installation steps seem to suggest you won't need to do the first two steps listed.
Acura Integra Power Steering Motor Replacement 1781624903935-59
Though, I would replace the O-ring (Part Number: 53106-S0A-003) and make sure you follow this lubricant specification.
Acura Integra Power Steering Motor Replacement 1781624634092-xm
AlexO
Alex
Ferndale, WA
2024 A-Spec Tech
Thank you for this info. Looks like replacing the motor should be no problem.
I called a couple dealers and the O-ring is back ordered with no ETA, unfortunately.
