Gas tank size
Nivek2slick
Kevin
La habra ca
Acura Integra type s
So I could swear that on a full tank I've gotten to 310 and for sure minimum 275 but today I filled up and it was 254. Has anyone else had this problem and what does everyone else get on full tank
Acura Integra Gas tank size PXL_20231129_144634901
FooBird
Washington
2024 ITS PWP, 2014 Tacoma
it’s a small tank for sure. Most every tank I have had is about 250-260 miles with 50/50 mixed driving. Haven’t gotten to take it on a long road trip so I can’t say what my max is.
There is a slight difference in mileage if you switch to comfort from what I experienced and a pretty big difference if you rev it and squeeze the accelerator more (215 miles range vs. 260).
Nivek2slick
Nivek2slick
Kevin
La habra ca
Yeah I average like 22.5 mpg which is fine I just thought tank was bigger . I do individual mode pretty much everything sport + except for suspension
Small tank. low fuel light comes on at around 3 gallons left. Range varies based on the drive. I had 2 bars left and ripped it 1st through 3rd and the low light came on at about 220miles.
Nivek2slick
Nivek2slick
Kevin
La habra ca
Oh wow low light on 200 miles I would be thinking has a hole in my tank
Lol. 22 mpg at 10 gallons is 220miles. Tank is only 12 gallons.
Nivek2slick
Nivek2slick
Kevin
La habra ca
Yeah exactly when I do math but as you see in pic it's what I average 22.5 I do mix of hwy and city and rip it occasionally
I'm averaging 24mpg but my low fuel light came on at 220.
Nivek2slick
Nivek2slick
Kevin
La habra ca
Maybe I'm confused 220 miles low fuel light comes on ? Mine doesn't come on until 41 miles give or take . I let it run until about 20 miles and then I fill up . Here in Cali we only have 91 so I put about $45-$50 to fill up
ChromaPop
Franklin, TN
Could it be learning your actual average MPG driving habit and therefore estimating based on that now?
Banned
Banned
Adios Amigos
Integra 1.5t
have it reset after filling up. should be getting a real time read out for the current tank.
It doesn’t give current MPG, it is just average MPG since you last had it reset. Since most Type S’s are still low miles, it’s the average MPG since it was received from the dealer, unless you reset it. Like @nawfoo said, you would have to reset after every fill up to get current fuel tank average MPG
Nivek2slick
Nivek2slick
Kevin
La habra ca
Yeah I never reset it ..I'll reset it to see what I get for mpg but the full tank shouldn't be effect from that correct ?
FooBird
Washington
The car quoted MPG are also a bit off. Mine always reads high compared to a hand calculation when I fill up my car.
I take 15-30 seconds to fill out a spreadsheet when I get gas before resetting the trip computer. Also, the trip computer when you reset keeps track of the last few tanks (assuming you reset trip A on refill).
Helps me understand the empty light info, driving habit trends, any drift as the engine ages, and how awful the trip computer is (~1 mpg high like my 9th gen Civic).
Acura Integra Gas tank size IMG_0589
