Center Brake Light Strobe Module
NHCivicGuy
NHCivicGuy
NH
2021 R
Thanks for this! Was a little intimidated by phothrottle's video the CTR instructions. Glad it's much simpler in ITS.
I'm glad it's easier on the Integra, too! I wish they were all that simple to install.
acurax
Are there modules for the lower brake lights? I only ask b/c studies seem to suggest both high and low brakes lights flashing may be better than either on their own.
NHCivicGuy
NHCivicGuy
NH
2021 R
I can definitely look into building them for those. At this time, you can buy my “DIY” model and splice them in for virtually any brake light.
I went with the center brake light only because it’s “subtle” enough for most buyers and it still provides that extra attention. When I post polls about it, most only wanted the center one, as they thought the side brake lights would be too much and obnoxious.
acurax
Maybe them being too much and obnoxious is what those studies are picking up on. 🤣
TacoShop
Robert
Las Vegas, Nevada
If you still have one for the type s, id take it off your hands. Lmk!
acurax
So, looking at the wiring diagrams, it looks like you may be able to tap into the brake light signal wire for all brake lights on connector C224, position 10, which is located behind the passenger side footwell kick panel. I confirmed this the same across all trims for 2024. Which might be easier than installing at the high mount brake light location. Take a look at these images and let me know if that's accurate or if more information may be needed to confirm.
Acura Integra Center Brake Light Strobe Module Screenshot 2026-06-04 104013
Acura Integra Center Brake Light Strobe Module Screenshot 2026-06-04 104339
NHCivicGuy
NHCivicGuy
NH
2021 R
That would be very nice! If you could PM the connector photos or part numbers, if you have a way to get that? I’m really curious to see what connector it is, and if it has both power and ground, as the diagram only seems to have 1 and my module requires both.
acurax
So after looking at the diagrams there are some important things which use that same connection, i.e. wheel speed sensors (RED/YEL, LT_GRN/WHT), parking brake actuator (YEL/GRN, RED/BLK), EVAP Canister Vent Shut Valve (LT_GRN/PUR). Even though those would just pass through, I'm not sure how finicky they may be. There's one wire that I have yet to locate in the diagrams.
Acura Integra Center Brake Light Strobe Module 1781791947988-xr
Acura Integra Center Brake Light Strobe Module 1781791991004-s2
Acura Integra Center Brake Light Strobe Module 1781792047192-ls
Acura Integra Center Brake Light Strobe Module 1781792094659-sm
Acura Integra Center Brake Light Strobe Module 1781792139788-yr
