Burples and pops GONE, Fixed.
ITSDAD
M
2024 ITS
I only cleared the code but haven’t started it back up yet. About to shortly and then drive it though. I’d like to avoid disconnecting the battery if possible. That’s what I felt led to all this anyway.
Question - why is it to clear code and then disconnect battery in that order? And is it true to always remove the negative cable first? Is there something about the length of time while disconnected that something happens? I guess I don’t want to reset my ecu since I’ve flashed the tune onto it, but how do you reset the ecu?
D-Rob did confirm that a dirty MAF would not give me my particular code of p0420.
Curious, do you happen to just have the tune flashed directly to your ecu without a hondata flashpro?
Wouldnt you need the flashpro to go back to stock?
Just trying to figure this tuning situation out, still need to send mine out to unlock and wondering if i need to grab the flashpro in the meantime.
It doesnt seem like disconnecting the battery works like it used to, I tried disconnecting and also pulling the ECU fuse when I initially got the CEL and it did nothing for me.
Mine is all done after ECU unlock and Hondata FlashPro. To my understanding, that’s the only way to tune this platform currently.
Update that clearing the code has worked for me so far.
slo_its
GTA, Canada
2024 ITS
Clearing code worked for me as well. Did not need to disconnect battery. Mine was related to stored code from when I forgot to plug in the sensor after removing intake.
koatic
koatic
Bryan
SouthEast
It is only recommended to disconnect the ground first because that connects to the chassis. if you are trying to disconnect the positive first, your rachet has a potential to accidently ground by touching the chassis while loosening the positive which would cause a short.
disconnecting the battery should not affect any tune flashed to the ECU's eprom.. if tunes were stored in the ECU's volatile memory, we would have a lot of bricked cars when batteries die.
Reason I suggest clear the codes and then reset is after extended battery disconnect (enough time for all capacitors to discharge) The ECU goes through a new learning phase and system checks. Thus, you get a prompt on the dash "system initializing continue to drive normal"
this seemed to fix the issue for me the second time after I cleared the codes and it still was not "acting" normal.
Thanks for the explanation! I got the turbo installed today but I will check the code reader again to see if there’s any background codes. So far all is well with exhaust sounds and no CEL’s.
koatic
koatic
Bryan
SouthEast
:love: What Turbo did you upgrade too? increase/decrease in lag/spool? guess with d-rob tune you are able to up the boost some and not just dependent on MAF? With all that extra airflow (HVI and such are you going to upgrade to a race MAF?
Do tell.. maybe start a new thread as I believe this will be a nice topic?
27won Kuro! It’s supposed to have no turbo lag and begin spool at 2k rpm’s and give a gradual boost to help retain more traction that some other the higher power turbo that give you all the power at once and still start around 3k rpm’s.
The base tune feels slow as heck until the revisions come after data logging. The TSP tune I had was faster than I am currently with the base turbo tune to make sure all is functioning properly before going back and forth doing the e-calibration style tuning.
I don’t think a race MAF is available for FL5 or DE5 yet? At least not that I’ve seen. I don’t believe they’re cross compatible with the FK8 actually. But I’ll double check for sure. A build thread would be nice. I need to make some time for it ? I have all these videos that I’m supposed to edit and put on my YouTube but haven’t done a single one yet. ? Just not enough hours in the day!
MidwestDE5
David
Quad cities Iowa
24 Integra type s, 21 Audi A5, 15 GMC Sierra
Let me start by saying my type S is completely stock with 1100 miles. I took it out for a few short drives last weekend enjoying all the pops and bangs on the way. Sunday afternoon I take it out for a short run. Once it gets to temp I flip to sport+ and no pops and bangs. All exhaust notes sound muted more like a sport mode or less. No check engine light or operating issues of any kind. Having already read this thread I went on Amazon and ordered a $20 OBD scan tool. Today I ran a scan and got “EVAP Svstem Leak
Detected (very small leak)”. Cleared code and headed out on a drive. Once I was up to temp I flipped to sport+ and immediately the pops and bangs are back.
Quinn Regis
IntegraQ
Ontario Canada
Interesting! pops and bangs on my car reduced significantly of late. I noticed a strong exhaust smell, which immediately thought was an emissions problem. Similar issue on a Fiesta ST I had. I will use my scan tool. Thanks!
Jcoco
Jeffrey
Integra Type S
Appreciate it, is it this one?
https://www.ptpturboblankets.com/pr...bo-blanket-hybrid?_pos=1&_sid=865024072&_ss=r
I'll def look into it, not in any immediate rush, did you happen to order via PTP?
I just found it curious that PRL has a brand specific PTP blanket, couldn't figure out for the life of me if there was any difference.
I read that you recently installed the PRL HVI, after installing mine my "pops and burbles" do sound less pronounced versus before, I just assumed it was the increased air flow dynamics altering the sound.
I Would be curious to know if anyone else has this issue.
For reference prior to the HVI install, I had only done the DP and RMM which made the exhaust seem louder to me.
I just installed the PRL HVI. Running into the same issue with pops and bangs being less aggressive. Wondering if yours came back or were you able to figure it out?
ITSDAD
M
2024 ITS
Hey, so im not sure whether its related or not, but I also have a downpipe installed. I originally chalked it up to just a change in AFR, however one thing I did notice was my worm gear clamps had loosened after a few drives.
I retightened them and that seemed to help. Not entirely sure whether that was the solution. I also have to repeatedly clear my ecu due to the downpipe constantly throwing codes, havent had a chance to unlock and tune unfortunately.
Tldr; double check all your ring clamps, thats what helped me!
Jcoco
Jeffrey
Integra Type S
Will do! Thank you for the tip!
b0nb0n
Anthony
2024 Integra Type S, 1999 Civic, 1997 Celsior
Pops gone in sport+ and individual mode. Stock car. Zero codes pending and never a CEL.
Noticed as I began my 2 hour trip. Car sat for 8 hours then drove the 2 hours back. Never fixed itself.
What's the solution here?
Magnams
Milwaukee, WI
My car is also stock. I lost my pops and bangs this morning. Stopped by the dealership on my way home from work. They scanned my car and I got the same code as you, EVAP system leak detected, very small. I had them clear the code and pops and bangs returned.
I am just wondering, did the problem ever return for you? Did any other issues ever come down the road? Or was this just a one off thing?
