A Multi-Port Option
https://www.stratifiedauto.com/inde..._RnT5T_QAQc03YvAveQxV9XGbkkzLSZ2Wv08iEwzlXpDW
Looks like they made a split second controller compatible with the Radium kit. Cool to see someone try this direction. I'm not sure if the benefits of cleaner valves outweigh the extra complexity of the setup, but it does seem to be more cost-effective than injectors + HPFP.
It will be interesting to see feedback, etc. if this gains traction.
bisquick
Brandon
Following. Curious how this stacks up against the HPFP/Injector route.
The price is appealing.
Considering a Full-Race HPFP + Hondata injectors will run you $4k alone lol.
Yep. And, the install here seems less involved. Assuming it proves to be reliable (re: performance of the split second controller, etc.), this could be a really great development.
SKINNIE
DFW TX
ISF, 23' BB FL5
UWU
colorado
type s
Does it work like a GTI, where port injection only works during cold start and in wide open throttle (together with direct injection)?
It just supplements the OEM injectors. Implementation would vary based on how you tune. The guys in the video just leveraged the port injection for fuel needs beyond OEM at wide-open throttle.
UWU
colorado
type s
Oh ok. Early days then. Pass.
Yeah, this particular option is new to market. That said, your tuner could theoretically leverage the port injectors on cold start. If they did that here, they didn't show it. Their stated goal was just more power.
anid0419
Andy
Vancouver
24 Integra Type S
My car there, the kit has been solid, the port injection only works when you need more fuel.
Cost-effective and you can run ethanol, tho the downside right now is that there is no flex fuel support. Really hope Cobb will add that in the future.
Is it Cobb only, or can you integrate with Hondata Keep us updated - cool to see someone take a different route!
JesterTuned
FL5 Type R, S2000, Ram TRX
It is a cost effective option but in my opinion not worth it. Due to needing to calibrate the system separately and it will always run independent from the oem ecu.
UWU
colorado
type s
Nice way of saying “extra point of possible failure” 😂
personally wouldn’t mind port injectors myself. Not for wide open pulls but to spray fuel on the valves during cold start
the fa24 gr86 has dual injection. Have seen them torn apart at the shop too. Their intake valves are clean. Spotless! Definitely hating on them 😂
definitely a waste of money to do this + cool intake manifold just to remove the need to blast the valves every decade. But it’s something to do, plus cool new intake manifold. That’s a plus 😂
hopefully the tech and its controls continue to evolve and get better 👍🏽
Agreed -- would be nice if Hondata did a "plug and play" module (like they did for Flex Fuel). I doubt they would, though... it would compete with their DI products.
