24 ITS problem when engine breaking
So what is it
  • Wheel bearing
    Votes: 0 0.0%
  • Gear box
    Votes: 0 0.0%
  • Some kinda bearing
    Votes: 0 0.0%
  • Trans problem
    Votes: 0 0.0%
  • Total voters
24ITSowner
IntegratypeSown
Fort worth
2024 Acura Integra type S
So I hear this whirring or howling noise when I’m decelerating at high speeds is when it’s most audible and at low speeds not often but sometimes. Just driving me crazy crazy it sounds like it’s coming from the front right side. If I take a sharp U-turn, it makes a certain noise that I can’t really describe by typing. i’ll attach a video of what it sounds like in fifth gear at about it’s a high pitch noise that’s driving me nuts and I just wanna know what it is and if it’s covered under my premium care warranty. I feel like it’s wheelbearings I did a deep dive… it did nothing but make me more worried that it’s everything but.., possible powertrain gearbox differential CV axle. None of it really made the noise that I’m hearing from the watched videos but when I swerve to the right, it becomes more pronounced and when I swerve to the left it goes away when I accelerate it goes away. And in neutral it is semi there but not nearing as much. Any help would be appreciated. I’m at 26,800 miles. And I apologize for the absolute shit video for reference. It’s kind of hard to drive and record to catch a sound, but you can hear it right as I stop accelerating. And it happens in 2-3 in 4th 5th and 6th it’s much more audible between 3500 and 3000 is the most noticeable. And as far as the video the best I can say is in the very beginning. I know there’s a lot of rumbling noise of me moving, but that high-pitched wine is what I’m referring.
East Coast
I can't tell from the video what i'm listening to, but if the noise you're describing only happens when you let off the accelerator, i'm pretty confident you're hearing the electronic wastegate. apparently it is supposed to sound like a rock is stuck in your rotors (albeit much feinter). hey it's a feature, not a bug, apparently lol
ne_de5
New England
‘24 PRP DE5
I doubt it's a bearing at that mileage, but just drop the keys off at the dealer? Idk why you're stressing about this.
My guess is that a rock got stuck between the rotor and heat shield.
have your tires been checked? At 26k miles try the easy stuff first.
rotate your tires and see if it makes a difference. I know your stuck on the sound but a worn tire, bubble or even loose lug nuts can cause weird noises just like that.
Krazydan19
Austin, tx
Shit 26 miles. Should already be on 2nd set of tires. I 2nd check the tires if haven’t been replaced
24ITSowner
IntegratypeSown
Fort worth
So I hear this whirring or howling noise when I’m decelerating at high speeds is when its most audible and at low speeds not often but sometimes. Just driving me crazy crazy it sounds like it’s coming from the front right side. If I take a sharp U-turn, it makes a certain noise that I can’t really describe by typing. i’ll attach a video of what it sounds like in fifth gear at about it’s a high pitch noise that’s driving me nuts and I just wanna know what it is and if it’s covered under my premium care warranty. I feel like it’s wheelbearings I did a deep dive… it did nothing but make me more worried that it’s everything but.., possible powertrain gearbox differential CV axle. None of it really made the noise that I’m hearing from the watched videos but when I swerve to the right, it becomes more pronounced and when I swerve to the left it goes away when I accelerate it goes away. And in neutral it is semi there but not nearing as much. Any help would be appreciated. I’m at 26,800 miles. And I apologize for the absolute shit video for reference. It’s kind of hard to drive and record to catch a sound, but you can hear it right as I stop accelerating. And it doesn’t happen much or at all in 1-3 rarely in 4th and always in 5th and 6th between 3500 and 3000 is the most noticeable. And as far as the video the best I can say is in the very beginning. I know there’s a lot of rumbling noise of me moving, but that high-pitched wine is what I’m referring.
24ITSowner
IntegratypeSown
Fort worth
I have an Audio recording I cannot post cause idk why. It’s not a rock or heat shield. It’s not wastegate. This is a whirring or a howling higher pitched. If you listen to the very beginning of the video before I’m shuffling around you’ll hear the wine. It’s not “normal engine noise” it’s audibly something wrong. Just trust. And as far as the comment on not the bearings due to low mileage. I’d agree. But I’m not gonna lie. I’m 100% usually racing or driving at 120/160. I’m worried the premier care won’t cover it cause I just dropped 77k on downpayment on new house and tbh banks kinda feeling rough. And my VSC is worded very weird. Last thing I need is a 500$ part cost and 2k $ labor for repair. And you might say. Nahhhh they won’t charge that much. I had a vent pop out of the clip in center above ac control unit. Got told 598$ for repair. Even went as far as to tell me the part was only 64$. And I didn’t even know I had premier care package until yesterday. They’ve been charging me for services ie air filters for cabin and engine fluid replacements break lines and even refused to replace a tire I had to get changed cause my tire blew on a Sunday and they weren’t open I was 82 miles from any dealership and I had to get it off the side of the road. Now I have a diff brand tire cause they won’t replace one that “still holds air” even tho I have premier package and rims tire and windshield warranty. I’m getting fucked by the dealers and charged out the ass. that’s why I’m worried. Imma make another post with irrefutable evidence of the noise, I’m referring to for the knowledgeable and experts within this page to give me An educated answer. n
same. I mostly just hear noise from the camera shuffling around.
24ITSowner
IntegratypeSown
Fort worth
The best I can see is the one who said that it was a waste gate Actuator. You’re hearing the noise. That’s good. That’s not the wastegate. It’s from right side front end. And when I swerve right it gets worse. When I swerve left it stops. When I gas it stops. When I break it stops. get
ne_de5
New England
‘24 PRP DE5
A) You need to go to a different dealer
B) You need to explicitly state that you want a warranty diagnosis. This is covered under your bumper-to-bumper manufacturer warranty
C) Do not mention that you're beating on the car. If you have any modifications, stickers, anything, just remove them
D) Just be professional and firm
I'm shocked that you're worried about warranty coverage on a new car. Unacceptable, go to a different dealer or speak professionally to the service manager.
I went back and listened to it more intently and I think I hear what you're saying now. It does sound like kind of a mild howling noise.
East Coast
these message boards have an atrocious filesize limit for attachments, like 25mb or something. i can't even upload photos that my phone takes because they're too big lol.
we really want to help you, it's just hard to tell from the video that you posted because the audio quality is very poor. do you think you could get a neighbor or friend to stand next to your car to record it while you drive around in a parking lot or something?
ITSDAD
M
2024 ITS
Ignoring everything and volume cranked to 11, I think I can hear it from around 2-5s and then again from 12-14s. Its hard to tell from the audio quality tho it sounds similar to a dry bearing being spun, or even a cracked CV boot, but definitely a howl. The tempo sounds consistent with the speed of the car/rotation of the tire so probably a wheel/axle component?
Just speculation.
24ITSowner
IntegratypeSown
Fort worth
Front two replaced back two old. They won’t replace unless it’s unable to hold air
