ashmostro
ashmostro
CivicX Basic Sponsor
Ash
Northern VA
www.s2iaudio.com
2025 ITS
Oh, and I scrapped the plan of running the sub off of the DSP amp (would be 250W into 4 ohms) and instead bought a 700W@1 ohm amp for max headroom. The sub I bought can be wired for 4 or 1 ohm thanks to its 2 ohm DV coils.
Acura Integra BUILT: Digital Factory Infotainment Integration for ELS Studio 1770174291343-5
ashmostro
ashmostro
Ash
Northern VA
www.s2iaudio.com
2025 ITS
Folks, I have some pretty cool news (I think it's cool, at least)!
I have sleuthed ALL of the connectors to and from the factory ELS amplifier, which means I can build T harnesses for myself and anyone who wants to go full factory integration with a DSP system (ie, not just the subwoofer, but all outputs).
I've ordered what I think are the right connectors from Mouser, and if I confirm that they are in fact the right ones, I'll post back up here.
No one, literally no one I've contacted in the industry knew what the output connector is for this amplifier, let alone where to source it. I've spent months searching for it, and found it "accidentally" today. I'm buzzing with excitement!
I've also figured out exactly what type of connector the factory uses for the digital input signal to the amp, so we will have options for the more typical, easier, but lower fidelity speaker-level A/D/A DSP conversion method, or the higher fidelity but more complex and less common OE amplifier bypass/direct digital input to DSP which is the approach I'm going to try to make work first.
But, either way, you need a way to feed the aftermarket amp's speaker outputs into the factory speaker wiring so you don't have to run all new wires into the doors. This is where the T-harness I speak of above comes in, and why it's so exciting for this platform. It allows us to do all this in a factory reversible manner (no cutting of factory wiring).
Stay tuned...
ashmostro
ashmostro
Ash
Northern VA
www.s2iaudio.com
2025 ITS
Progress is being made! I have started building the custom connector to inject signal to the factory speaker wiring harness. Tomorrow, I'll start on the input side. Next will be the proprietary volume signal converter, then power wiring for the amps, mounting the amps, then the speakers and sound deadening.
Acura Integra BUILT: Digital Factory Infotainment Integration for ELS Studio 1771034043401-3n
ashmostro
ashmostro
Ash
Northern VA
www.s2iaudio.com
2025 ITS
I'm curious - who here would be interested in a complete T harness for full system integration (specifically analog speaker level input, not pure digital conversion like I'm doing)? This harness would enable intercepting every independent OEM channel into your DSP/amplifier.
Building the harness is a pretty involved procedure since the output plug on the ELS amplifier is so new that there is only a board-mount connector available, rather than the much easier to assemble cable-style plug.
I'd be interested in breaking the sub out from the rest.
That would be quite easy actually. But I'm curious - why, when you can just intercept the signal at the sub in the trunk? What's your design goal?
Line level vs speaker level. I'm not sure it would be worth the effort, just curious.
ashmostro
ashmostro
Ash
Northern VA
www.s2iaudio.com
2025 ITS
Ah, sorry I wasn't clear at all. Tapping into the signal at the amp or the sub is the same thing. They are all speaker level outputs. The factory system has no line level inputs, just a single stereo digital input that the amp converts to analog and then amplifies after processing it.
The t harness I'm proposing would be to intercept every single speaker output signal so you can use a DSP to reconstruct the original signal with summing and eq. This is the most common factory integration approach. But as you suggest, it's not the highest fidelity solution which is why I'm going full digital.
For your sub-only use case it would be unnecessary complexity and wouldn't change the sound quality at all vs tapping in at the sub since it's electrically identical.
The t harness I'm proposing would be to intercept every single speaker output signal so you can use a DSP to reconstruct the original signal with assuming and eq. This is the most common factory integration approach. But as you suggest, it's not the highest fidelity solution which is why I'm going full digital.
That's what I would have expected. I misinterpreted your explanation of the connector... wishful thinking 😂
ashmostro
ashmostro
Ash
Northern VA
www.s2iaudio.com
2025 ITS
Accomplished a lot today. My goal was to decode as much of the factory head unit and amplifier "signals" as possible. Things I wanted to understand:
  1. Is system volume command carried on the RS485 signal? Answer: YES
  2. What are the extents of the HEX code for volume:
    • Min (= 0) on HU = 0xFE hex (= 94) on RS485 signal
    • Max (= 40) on HU = 0x5E hex (= 254) on RS485 signal
    • 40 steps on HU = 4 steps on hex code, so very easy math to set up the digipot
  3. Can the factory head unit function without the factory amplifier connected? Answer: YES-ish...
    • The factory HU did not seem to like the SPDIF connection being severed as some functions stopped working when I did (but not all).
    • I found that if I plugged the SPDIF back in but kept all other amp harnesses unplugged (ie no power to the factory amp) the head unit was happy again.
    • This implies that the SPDIF is not bidirectional and the HU is only looking for a load across that terminal to be happy. This is very good news.
  4. Are beeps/navi/parking sensor chimes, etc analog signals that I can feed into my DSP amp?
    • Yes. They do not appear to be proprietary digital signals which means they can be fed into a DSP amp with signal ducking enabled, which mutes/suppresses the music signal whenever it sees signal on any of these inputs.
    • This will preserve the factory auxiliary sounds like phone calls, beeps, etc.
  5. Does the factory microphone still work without the amplifier connected and powered up? - YES!
This may not seem like much progress, but this data proves that the full digital system configuration is totally doable. I might even remove the factory amp and see if one of the aftermarket amps can fit in that location (it's a tight fit though, so we'll see).
Acura Integra BUILT: Digital Factory Infotainment Integration for ELS Studio 1771272149844-k1
Acura Integra BUILT: Digital Factory Infotainment Integration for ELS Studio 1771272296482-f6
Just a note for the future when identifying things @ashmostro, I've had really good luck with getting Ai (chatgpt, Claude, and copilot) to identify fittings, ports, and such by photo. A neighbor lost one of my power plugs for a beefy 120W RMS Bluetooth speaker, and I couldn't find it anywhere. One photo to Claude and it found a myriad of sources in whatever length and finish of choosing.
ashmostro
ashmostro
Ash
Northern VA
www.s2iaudio.com
2025 ITS
I used AI for a lot of this but it was pretty useless for the newer non-documented connectors like the 26 pin one I took months to find. It's literally not even on the manufacturer's website yet, so AI was totally useless and pointed me to the wrong connectors over and over again.
We're not at AGI yet....
Yeah we're not, but we are getting slightly closer on some ends. When I can get an ai to truly replace me, I'll be in my happy place!
I'm really curious to see where you end up! Wish you were closer so I can hear it.
I've gone as far as I'm willing to go on my its. Replacing the door speakers just isn't in the cards since it will soon be relegated to being a 4th car. I've accepted it will be just okay compared to the bose 🤮 in my q7 and mediocre compared to the Harmon in the X7. The its relies heavily on the 3d gimmicks. Despite all the playing around with the settings, I've found it sounds best across the gamut of music by leaving all the crud on. Only with older rap, older hip hop, and classic rock does it benefit from turning the 3d off. I do need to rip out the center and do something to seal and add weight to it. Or maybe just replacing that one driver.
