- First Name
- Gordan
- Joined
- Jul 9, 2024
- Threads
- 12
- Messages
- 1,468
- Reaction score
- 1,014
- Location
- Kansas City
- Car(s)
- Integra type s
With 18s your load rating is also much higher so 29psi is equivalent to 35psi in oem load rating.That's good to know. I've definitely been experimenting with tire pressure lately. Sounds like I'm too low. On the 275/35/R18 tires in my pics, I was running around 34 PSI front and 31 PSI rear (cold). Sounds like that might be a tad low.
Thanks for the info! I'll try some higher pressures when it's time for summer tires again.
On the 265/30/19 i found 44/40 to be pretty well balanced at the track, but it will change depending the surface and track. I could have further tuned driver front to 46, passenger 43, rears 40/40.
44psi on oem tires is 34psi and 40 is 33. Sounds like you're not terribly far off, but if you're on 9.5" wheels you might need that bumped 2-3psi still to account for the significantly wider tire footprint (the oem 265 dt1 is narrower by 3/4" than 265 regular ps4s so the 275 is i bet a whole 1" wider).
