Auto start/stop "temporarily disabled"
a1rwolf
Oren
2025 Integra A-Spec Tech 6mt
I have a 2025 Integra A-Spec Tech (manual). I'm noticing that the auto start/stop feature temporarily stops working when the car is starting to get low on fuel (range 70-80 miles). Anybody else notice this? Is that normal? Doesn't it seem counterintuitive? Or is it because starting an engine consumes more fuel than the few extra seconds of idle?
elh0102
Ed
I am forever thankful that they did not include this feature in the Type S. I had a Porsche with it, and I turned it off and forgot about it, suggest you do the same.
a1rwolf
Oren
I just recently got the car and don't mind it. Actually appreciate it in some ways. If I get ever get sick of it I'll disable it. But not there now. In any case just looking for an answer.
cpknillv
Chuck
us
2023 acura integra a-spec mt
It does disable it with low fuel or engine not being up to temp and other factors. I would recommend disabling though because the auto stop start does not actually save on gas and is very hard on engines, especially turbo charged ones. Turbos need a spool down time before they are shut off otherwise you risk early failure. I also recommend that you should idle your car for a minute when you park to let the turbo wind down and oil to flow out a little.
slowcountry
Dylan
Arkansas
Hate it even on the CVT, feel like it throws off transmission oil pressure. There's a fluid pump on the transmission that's supposed to keep that pressure constant during auto start/stop, but sometimes it totally lags.
I toggle it off every time I drive, perhaps I should check if there's a permanent setting Lol. Only thing that comes to mind is the sport mode or setting it in individual mode.
Bad bro
Kevin
Comox, BC
2026 Integra ASpec Elite 6MT and 1969 AMC Javelin SST
Turbo killer? Lack of lubrication with stop/start. Turned off.
Equally glad they didn't put the tracking module. Yeah it sucks we don't have the LogR feature but in my books, having my car be isolated from Skynet is th bigger benefit.
My only let down is that the CMBS reactivates every drive.
To OP, take this as a win. IMHO, you should be turning it off every time you start the car if you actually care about it and want to keep it long term but I wouldn't worry about this "problem".
