Redline Manual Transmission Fluid Change
UWU
colorado
type s
A little off topic, but do you guys know the torque spec for the transmission fluid check plug/bolt? I tried following these torque spec but can't see anything specifically for that bolt unless it's registered as a fill plug. So far I've just snugged it down and will check for leaks, but would like to know if there's a recommended torque for it.
32 ft pounds
Whoa isn’t that way way different than the oem viscosity!?
Probably gear vs crankcase oil grade rating. It's silly, but it's not a fully standardized weight and viscosity system. One gear oil 80w could be as close to a 20w or as far as a "35w" crankcase oil. While that 20w crankcase oil with one product might be to a 30w for another product, especially at higher operating temps.
Google for a oil viscosity weight comparison chart and you'll get the idea.
UWU
colorado
type s
Oh ok yeah I’m familiar with that fuckery. Didn’t think that could’ve been what split them. Thnx for reminding me
