Power Seat memory won't save/update
white23aspeccvt
2023 Acura Integra A-Spec CVT Tech Package
Driving a '23 Integra. I believe in the past when I pressed the set button, it lit up yellow and I could save a seat position but when I try to update it now following the same steps, it lights green when set is pressed and beeps twice quickly when I press a seat option, but won't save and just double beeps.
The car still slides back and forth when turning the car on/off. The infotainment system has the driver position memory enabled so trying to figure out what's going on here. Why am I unable to update my memory seat?
I tried to press and hold down set then seat 1 and the green light will turn off after 5 seconds but it doesn't seem to do anything. What am I doing wrong or how can I fix this?
Only changes to the car that I'm aware of is installing a dash cam and starting to use Acura Link.
The double beep sounds like correct behavior. If you move it after saving and then press the 1, is it not going back to the spot you set it to? The owners manual says you have to be in Park to recall the memory.
Are you using the correct key fob? Try using the other one and see if that'll recall the memory when you get in the car.
If neither of those work, try disconnecting the dashcam and see if that fixes the issue. A quick google search said a yellow light may indicate some kind of wiring issue - either a lower voltage than expected or a bad connection. How did you wire the dashcam?
white23aspeccvt
Hmm, I swear I tested 5+ times and it wasn't sticking but I think it's working now?
