Engine noise . Not the injector noise. Anyone have any ideas
joeryu
jose
New jersey
24 integra type s
ashmostro
Northern VA
Yikes! Any codes? How's it driving?
I just found a rattle on my engine cover and removed it. It needs to be spaced out with some rubber washers which I've ordered. But it wasn't rattling at idle, just at 2500 RPM.
Still worth pressing on the cover to see if it's that, but it unfortunately sounds like rod knock to me...
2012Baja
Eric
Direct injection is noisy and I have seen more than a few videos of type R's with this same noise. as well..
ashmostro
Northern VA
There's two noises there fellas. Ignore the injector noise and listen for the knock.
2012Baja
Eric
Same noises... all are on the belt side....
jedi03
Aaron
New Mexico
2025 Integra type s
Tensioner, alternator an ac compressor have bearings that can sound similar...run it for a minute without the belt for that. There's a timing chain tensioner an the cam gears can also make noise when they are going out
