Condensation in headlight - 2023 Integra A-Spec
Nileism
Nile
2023 Integra A-Spec
Hello all,
I was curious if anyone has run into this issue. The front right headlight on my Integra stopped working and appears to have a decent amount of condensation in it after washing it. I've looked online at replacing the headlight, but would prefer not to shell out $1000 bucks to do that.
Is it toast? Any DIY options I can use to dry and fix it?
TIA!
Be careful as if water short the connections, you might not be able to drive your car as the whole network won't work.
Saw this in a post on the forum when someone got water in a broken headlight.
Jetman
Joe
2024 Acura Integra
Just recently encountered the same on a 2024 base model. I went the route of buying new at Acura parts online. Yep $1000. I didn’t notice moisture in mine but have read that the LED driver is sensitive to moisture. I did learn that the one I replaced was from a salvage car.
