Brake change question
24ITSowner
IntegratypeSown
Fort worth
2024 Acura Integra type S
So there’s like zero videos online about changing out the brakes. The only thing I could find is the FL5 DE5 civic r brake change needs a specific machine to put emergency brake into service mode… apparently ITS needs it too. What machine is it. Where do I find one. I’m not gonna pay the dipshit dealership $951.89 to do my brakes. Any help!
jayy_swish
You can watch 10th gen Type R brake change videos if you’re a visual learner. They’re relatively the same set up
24ITSowner
IntegratypeSown
Fort worth
Does VSA mode not do it?
jayy_swish
There is no way to put the electronic E-Brake fully retractable back without some type of diagnostic tool or manually by disassembling the back and using a torx socket to retract it back
crepr12
North East
24 ITS Black on Black
Its simple to remove the parking brake its 2 crews and then retract...just make sure your parking brake is off and cyle the switch when done..plenty of vids online...ITS parking brake is not a one off design...
Braun
Anaheim, CA
2024 Apex Blue Pearl ITS
AHC Garage did a brake upgrade on an ITS. Maybe this will help:
Millest
Stephen
I was going to say the same thing. No way buying the scanner/tool is the only way. Should be able remove actuator and manually retract it.
