Which replacement ceramic brake pads?
lumper
2007 Nissan 350z
Shopping for brake pads, I have looked on Amazon, Autozone, advanced auto, summit racing and a few others.
EDIT:
Below, you can see I found 2 options, any thoughts on these set ups?
I can get the Brembo's front and Bendix rear.
FRONT:
Brembo P28104N Premium Ceramic Front Disc Brake Pad Set HONDA OE# 45022TVCA02 $58.00
REAR:
Bendix Premium SBC2102 Ceramic Rear Brake Pad $26.00
$102.57 shipped for all 4.
Saves me 58.00$
OR
Akebono:
Front
SKU: W0133-5410648
PRO-ACT Ultra-Premium - w/ Heavy Duty Power Disc Brake (RPO J55) Ceramic
$92.00
Akebono:
Rear
SKU: W0133-3105546
PRO-ACT Ultra-Premium Ceramic
$63.00
$170.00 all together for all 4 shipped.
Any thoughts would be appreciated.
Acura Integra Which replacement ceramic brake pads? d5fc68eb-f2d3-432e-aa26-39e195f9d5cd
lumper
lumper
2007 Nissan 350z
So, On Parts geek I found some Akebono's that they say will fit, I think I am going to order these.
Akebono:
Front
SKU: W0133-5410648
$92.00
Akebono:
Rear
SKU: W0133-3105546
$63.00
I am planning to order these today unless I hear otherwise.
bisquick
Brandon
Check out Rockauto. You have a bunch of options to choose from, most reasonably priced.
lumper
lumper
2007 Nissan 350z
Akebono:
Front
SKU: W0133-5410648
$92.00
Akebono:
Rear
SKU: W0133-3105546
$63.00
I also found OEM replacement for 1/2 the price.
FRONT:
REAR:
Saves me 58.00$
What would you order?
lumper
lumper
2007 Nissan 350z
I did start there but they either have fronts with no matches for rears or the other way around, I want to stick with one brand if possible unless I go OEM replacem34ent and go Brembo fronts and Bendix rears.
bisquick
Brandon
The Akebono front and rear are both listed under Premium.
Front: ACT1001
Rear: ACT1878
I've run this setup on my ITS.
lumper
lumper
2007 Nissan 350z
Front: ACT1001
Rear: ACT1878
These are exactly what I had in my cart.
So, you actually used these?
I was considering these vs the Ultra premium ones I listed for a little more.
Thanks for confirmation that they do fit.
EDIT
So, I had a set in my cart at parts geek, they were 50$ more all told, so I contacted them in chat to confirm they were the same pads and not a different model number or different more premium pad, turns out they are act 1878 and act 1001 so, I ordered them from Rock auto instead and saved $50.00
Thanks for the info.
lumper
lumper
2007 Nissan 350z
Front: ACT1001
Rear: ACT1878
Ok, so the ones you mentioned I had in my cart.
They are 50$ less from Rock auto than from Parts geek.
Thanks.
