Chirp in suspension
NancyJ
Nancy
North Carolina
Integra
I have a 2023 Integra A-Spec with 60,000 miles. I have a squeak/ chirp that has developed that is intermittent. Happens over bumps. I had to have a tire replaced and the chirp went away so I thought it was somehow related to that but then it came back. When I took it to the dealer it was being particularly quiet so I had to bring it home. Waited till it was super noisy and took the shop foreman for a ride and he heard the chirp. Made an appointment, dropped the car off and once again, they are telling me they can't recreate the noise and to pick it up. It's also make a scraping sound of some sort at higher speeds going over a ridge in the road. Any thoughts?
Swaybar bushings or links?
NancyJ
Nancy
North Carolina
Integra
Thank you Dan. It seems that once the car has been put on the lift it makes the noise go away for a few days, then it comes back. I feel like I'm in a catch 22.
AcuraDays
Alex
NY
2024 Integra A-Spec
Hi, did you ever figure this out? I’m dealing with the same issue and same responses from dealership and the car. I have 70k on mine and recently swapped the sway bar links out with OEM one’s at the dealership..
