19x9.5 or 18x9.5+45
Trojanlawyer
Rancho Cucamonga CA
2023 Acura Integra, 2022 Toyota Gr86, 2006 Z4
Anyone running a 19x9.5 or 18x9.5 +45. I'm wondering if there is any rub on the inside/strut.
HondaFan777
2023 Integra ASpec Tech, 2022 MDX Tech PKG SH-AWD
You’ll want +40 with 9.5 width.
trippvail
Tripp
League City, TX
2023 Acura Integra A-Spec Tech 6MT
I would like to know these things as well. Currently looking at 18x9 +40ish for my set up, want to run 255 tire 40 profile to maximize grip on it, but if a 265 on a 9.5 wide with a 40 offset will clear i might consider that more!
HondaFan777
This will work on a +40 offset. A lot of 11th Gen civic guys on the same set up.
iamnesty
Juan
Orlando, FL
2023 Integra/2022 Model Y Performance
I found wheels for a good price locally but they are 19x8.5 +30. Can I make this work? I was thinking with a 235/35/19 tire. Any help is appreciated.
Yes, that will work along with that tire size. That’s the size recommended for a 19 to keep the same overall diameter as OEM.
You can also use: www.willtheyfit.com
For reference, stock wheels are 18x8 +50 with 235/40/18
I’m lowered almost 2” and running a 20mm spacer in the front and a 25mm in the rear with ZERO rubbing.
Tegra808!
2023 Acura Integra Aspec
18x8.5 +38 offset front
18x9.5 +22 offset rear
SPC rear camber arms
Lowered on Eibach Sportlines
-3 camber rear
No need to roll fenders
No rub
nice…38 offset seems to work. Any rubbing up in front? Looks tucked.
