Hondabob
Hawkmoon2007
Civic Si
Proportions are a little bit different that I was expecting but the rear end looks really promising
Integra
Mustang
I was expecting a more pointy front, a bit less Civic like.
Integra
Mustang
It’s actually very reminiscent of this.
it is, I think I was just expecting something that harked a bit more towards a blended Integra/RSX front where it was less of just a blunt grill.
I'm also more of a fan of mirrors on the pillar not on the door. It looks more integrated instead of just Stuck on. It's one of the reasons I REALLY hated when the Si got a sedan version. The mirrors were moved to the door and made them look like an afterthought just stuck on. While the coupe still had them on the pillar.
RobbJK
Robb
Columbus, OH
2019 Honda Civic EX Coupe
I'm hopeful the full reveal will be promising, camo after all is meant to disguise and confuse. But a few things I noted when I could really examine the images closely...
- The front end does remind me a bit of the RLX/Legend front end especially the lower intake area, slightly disappointing as that seems like a design step backwards, however, the upper pointed grille treatment also has some strong Precision concept vibes which also had that kind of pointed bulging nose.
- As I had hoped, the Integra seems to borrow the flared fenders of the new CTR, giving it a wider and more aggressive stance
- I wish they had lowered the roofline slightly compared to the civic hatch just by an inch or two... the side windows seem so tall, and while I know Honda loves their airy cabins and lots of big glass, I like my performance oriented cars to feel a bit more... intimate with slightly shorter side window height. An upswept beltline would've helped this too.
- after comparing images back and forth, the load height for the hatch is definitely quite a bit higher on the Integra compared to the civic hatch, cargo loading won't be quite as easy, but the tradeoff is a better design IMO
- lastly, the back end profile doesn't seem quite as flat as the sketch they released, which is a bit of a letdown as it dulls the coupe-like shape and has the more rounded appearance of the civic hatch. Lowering the roofline a bit, or raising up the ending point of the hatch would've allowed for the more flat coupe look the drawing had.
I think perceived scale is playing a big part here as well... the car seems kind of large... but one has to remember that this will probably be almost the same exact height and length as the civic hatch, and imagining it in that context of size helps the sporty vibe. I'm still very excited to see it fully unwrapped and think very minor things like tinted windows will do a lot to help it really pull off the sport compact look. I'm also still very much hoping for a coupe variant to come that might lean even further into the styling but the 5 door is shaping up to be decent enough looking, and certainly better looking than the civic hatch. Now I just hope they get the power/performance vs cost in the right balance to make it really attractive.
jayevo23
CW CTR
Not what I was expecting. I thought it was going to be slightly bigger than a ILX for whatever reason. I never envisioned they would bring it back as what it appears a mid size sedan. I guess I gotta wait and see.
TigerEyeJazz
2019 BMW X2 M35i, 2023 Acura Integra A-Spec Tech
It’s still a Compact. Remember these where taken in a different angle so hold judgement till then.
SuperCyan
2017 Civic EX-T Sedan
It's based on the 11th gen Civic hatch, so it's gonna be a compact. Pics are little deceiving
RobbJK
Robb
Columbus, OH
The best way to envision the new Integra in terms of size and scale is using the 11th gen CTR as a starting point (it appears the Integra is getting the flared fenders similar to what the CTR has), and then just stick the acura front/rear on it. There's a few crease lines in the sides that are different from the civic, but roof height and such appear to be basically the same.
TigerEyeJazz
Yeah basically and that CTR is THICCCC. Not three C’s but four C’s that’s when you know it’s Thick.
RobbJK
Robb
Columbus, OH
I'm not sure they'll do the flares quite as much as the CTR, possibly reserve the CTR level flares for the Type S... but the fenders on the regular Integra are definitely more flared than they are on the regular Civic hatch.
TigerEyeJazz
I think Acura does flares differently then Honda. If we look back to the TLX when it got revealed, Acura stated that the TLX had Type S in mind which is why it has the wide rear arches on the rear with the Base and Type S versions. I think that it’ll be the same case here when Acura/Honda designed it.
