Not Allowing me to Change Modes
Rhinoplasti78
Miami
Hi there when ever I try to change the dynamic mode the car beeps and a message on the gauge pops up saying “Dynamic Change Mode Unavailable”. Something happens when I press individual and when I go to vehicle settings to make changes on the Individual I get a similar issue.
Has anyone else experienced this issue? Any ideas how to fix?
The only time I've (repeatedly) had an issue with the modes not working is immediately after reconnecting the battery. It usually fixes itself after I drive around the block and restart the car. If you didn't disconnect your battery recently and it still happens after driving a while, I'm out of ideas. Might need a trip to the dealer.
Same here, today after reconnecting the battery and took a drive cycle to fix. Maybe it would do this is the batter is simply low? Not sure if you have a tester to see what it’s reading
Rhinoplasti78
Rhinoplasti78
Miami
Same fixed itself as well after I drove around for a bit and got back in the car from the store it was working again
Hmm, that still sounds weird that it would behave this way if you haven’t messed with the battery at all. Unless there’s the slightest loose connection maybe that tripped it? Other than low battery life that is.
