RB2490
- Thread starter
- #1
OK so I recently installed the car hood lights and I tapped into the fuse box inside the engine bay. My only issue is that when I turn the car off the lights stay on unless I use the ir remote to turn it off. Now in past cars it has always been that if the fuse amperage is in ( ) then it usually indicates that it's a switched fuse and not constant. Now I have done my due diligence and checked each fuse to see if they remain on when the car is off but could be that all fuses are constant in the engine bay. I tapped into the fog light fuse which has ( ) around it. I don't want to splice any headlight wires to tap Into that. Anybody have any suggestions or a way to bring the wire inside of the car?
