Extended wheels studs
_Paul_from_Jax
Paul
Jacksonville
24 ITS, 09 JCW
Anyone else feeling like the oem wheel studs are a bit short for comfort? I'm sure that it's fine, but with the new open ended lug nuts, it appears that like only half of the stud is getting thread engagement with the lug nut.
I'm thinking about doing a set of extended studs. The part number that keeps coming up is ARP # 100-7744, which crosses to the FK8, but no mention of the FL5/DE5. I'm pretty sure that its tall the same between the 21 CTR's, but can someone verify by chance?
Probably not a big worry. I'm using apex rims and apex open ended nuts and the studs don't even make it to the end of the nut. Maybe 10 turns or so. Holds up at the track fine though.
